Delta.Skies Posted October 24, 2018 Share Posted October 24, 2018 Dont fully like the models, anybody made any variations to the aggressor. Want underslung bolters rather than off to the side. Scibor has great aggressor like models but they are heavily themed and expensive for one model. Any suggestions. Link to comment https://bolterandchainsword.com/topic/350808-aggressors/ Share on other sites More sharing options...
PeteySödes Posted October 26, 2018 Share Posted October 26, 2018 I havent seen any but i expect the challenge is the semi mono pose issues with how interconnected everything is. I'd encourage you to take the plunge though and get choppin' to make what your imagining! If you need some ideas for ammo belts these work great: https://www.zinge.co.uk/collections/flexible-resin I plan to make some but will likely just to some dramatic reposing. That will for sure require the aforementioned choppin'. Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5179388 Share on other sites More sharing options...
Delta.Skies Posted October 26, 2018 Author Share Posted October 26, 2018 ahhh man, dude thanks for the link, this is exactly what i need, was thinking of dreadnought stormbolters underneath power fist for this but didnt know how far. But this is very helpful. Thank you good sir Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5179618 Share on other sites More sharing options...
Guest Triszin Posted October 26, 2018 Share Posted October 26, 2018 nice find fearpeaty. Might grab some Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5179641 Share on other sites More sharing options...
Knightsword Posted October 30, 2018 Share Posted October 30, 2018 The Scibor models are great aren't they? Marneus Calgar's arms come to mind as the easiest option, but that would be very expensive. I would look at a little bit of green stuff, clipped down bolters and Terminator power fists from the Tartaros pattern box as it contains both left and right handed fists. You also go down the GK route and model the bolters on the knuckles. It's a shame chain fists are only left handed as those would make a good base for converting underslung bolters. I'm about to start modelling some Aggressors. I saw a conversion on here of some with normal power fists on one arm and then the Inceptor assault bolters on the other, with GK Terminator heads. Think I'm going to go down that route with mine. Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5181641 Share on other sites More sharing options...
old git Posted October 30, 2018 Share Posted October 30, 2018 Centurion arms, if you can get hold of them separately. Not sure about the fit on Gravis armour but the configuration sounds like what you're after. Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5181775 Share on other sites More sharing options...
FormelyKnownAsSmashyPants Posted November 30, 2018 Share Posted November 30, 2018 I havent seen any but i expect the challenge is the semi mono pose issues with how interconnected everything is. I'd encourage you to take the plunge though and get choppin' to make what your imagining! If you need some ideas for ammo belts these work great: https://www.zinge.co.uk/collections/flexible-resin I plan to make some but will likely just to some dramatic reposing. That will for sure require the aforementioned choppin'. Have you used these previously, as I found these again earlier today after forgetting about them? I’m curious what the “flexible” resin is like? It sounds kind of rubbery, like the plastic hero clix are made out of, and I worry about paint chipping and flaking off. I desperately hope I am wrong, as I want to make some landspeeders and Talonmasters for my Ravenwing, but don’t like the ammo feeds on the heavy bolters as I feel like they seem weedy for the bore size of the gun, and were sculpted in a time where they were unable to achieve what they can now, and don’t look remotely like bullets. Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5203370 Share on other sites More sharing options...
PeteySödes Posted November 30, 2018 Share Posted November 30, 2018 I havent seen any but i expect the challenge is the semi mono pose issues with how interconnected everything is. I'd encourage you to take the plunge though and get choppin' to make what your imagining! If you need some ideas for ammo belts these work great: https://www.zinge.co.uk/collections/flexible-resin I plan to make some but will likely just to some dramatic reposing. That will for sure require the aforementioned choppin'. Have you used these previously, as I found these again earlier today after forgetting about them? I’m curious what the “flexible” resin is like? It sounds kind of rubbery, like the plastic hero clix are made out of, and I worry about paint chipping and flaking off. I desperately hope I am wrong, as I want to make some landspeeders and Talonmasters for my Ravenwing, but don’t like the ammo feeds on the heavy bolters as I feel like they seem weedy for the bore size of the gun, and were sculpted in a time where they were unable to achieve what they can now, and don’t look remotely like bullets. It's slightly bendy with a wire core so it holds the shape. I haven't used the ammo feeds but have used the cabling parts and they are both durable and I haven't had chipping issues. As long as your using acrylics you shouldn't have issues. I haven't had mini paint damage in any significant way since the days of pewter so i suspect its not an issue. Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5203397 Share on other sites More sharing options...
Blindhamster Posted November 30, 2018 Share Posted November 30, 2018 anyone know what sizes would be right for aggressors? Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5203404 Share on other sites More sharing options...
PeteySödes Posted November 30, 2018 Share Posted November 30, 2018 anyone know what sizes would be right for aggressors? I suspect based on the pics, the small would suffice since theres other cabling that fits in there. (Spoilers for size) Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5203406 Share on other sites More sharing options...
FormelyKnownAsSmashyPants Posted November 30, 2018 Share Posted November 30, 2018 I havent seen any but i expect the challenge is the semi mono pose issues with how interconnected everything is. I'd encourage you to take the plunge though and get choppin' to make what your imagining! If you need some ideas for ammo belts these work great:https://www.zinge.co.uk/collections/flexible-resin I plan to make some but will likely just to some dramatic reposing. That will for sure require the aforementioned choppin'. Have you used these previously, as I found these again earlier today after forgetting about them? I’m curious what the “flexible” resin is like? It sounds kind of rubbery, like the plastic hero clix are made out of, and I worry about paint chipping and flaking off. I desperately hope I am wrong, as I want to make some landspeeders and Talonmasters for my Ravenwing, but don’t like the ammo feeds on the heavy bolters as I feel like they seem weedy for the bore size of the gun, and were sculpted in a time where they were unable to achieve what they can now, and don’t look remotely like bullets. It's slightly bendy with a wire core so it holds the shape. I haven't used the ammo feeds but have used the cabling parts and they are both durable and I haven't had chipping issues. As long as your using acrylics you shouldn't have issues. I haven't had mini paint damage in any significant way since the days of pewter so i suspect its not an issue. Thanks for that, I guess I’ll order some in the next week or two and try them out Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5203439 Share on other sites More sharing options...
Blindhamster Posted December 11, 2018 Share Posted December 11, 2018 For everyone's benefit, I ordered the smallest ones, I would say that they're a little small compared to the ones aggressors have. Very funky though Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5212368 Share on other sites More sharing options...
Cryptix Posted December 11, 2018 Share Posted December 11, 2018 Is this good funky or bad funky? Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5212412 Share on other sites More sharing options...
Blindhamster Posted December 11, 2018 Share Posted December 11, 2018 they bend really well and look nice! Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5212732 Share on other sites More sharing options...
Guest Posted December 11, 2018 Share Posted December 11, 2018 they bend really well and look nice! Got some pics? I am really on the fence about them Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5212778 Share on other sites More sharing options...
Dracos Posted December 15, 2018 Share Posted December 15, 2018 The Scibor models are great aren't they? Marneus Calgar's arms come to mind as the easiest option, but that would be very expensive. I would look at a little bit of green stuff, clipped down bolters and Terminator power fists from the Tartaros pattern box as it contains both left and right handed fists. You also go down the GK route and model the bolters on the knuckles. It's a shame chain fists are only left handed as those would make a good base for converting underslung bolters. I'm about to start modelling some Aggressors. I saw a conversion on here of some with normal power fists on one arm and then the Inceptor assault bolters on the other, with GK Terminator heads. Think I'm going to go down that route with mine. I really like this idea has any links to the original post or pics ? Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5215776 Share on other sites More sharing options...
Elzender Posted December 15, 2018 Share Posted December 15, 2018 I think this thread by ST. Lazarus is what Knightsword is referring to: http://www.bolterandchainsword.com/topic/334523-2018-12-12-tech-hermit/page-2 Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5215883 Share on other sites More sharing options...
Dracos Posted December 15, 2018 Share Posted December 15, 2018 Much thanks. Considering I plan on 10 Aggressors and 10 Plasma Inceptors this is awesome. Just need the Terminator power fist. :) Link to comment https://bolterandchainsword.com/topic/350808-aggressors/#findComment-5216177 Share on other sites More sharing options...
