Guest uk_crow Posted October 26, 2018 Share Posted October 26, 2018 Fellow Barons, how do you go about transporting your knights? I have almost completed my 2000 point list made up of 4 knights and just purchased a KR multicase to move them about in, the problem is because I haven't used standard poses they don't fit in the case. I've glued my arms on so i cannot remove them now... So the question is, how do you move yours about safely? I'm considering making a magnet tray case out of a deep toolbox (see below)https://www.screwfix.com/p/dewalt-tstak-vi-deep-storage-unit/1254f#product_additional_details_container lining the base with sheet steel and then attaching 4 of these magnets to the bases of each knight: https://www.amazon.co.uk/Neodymium-Diameter-POWER-MAGNET-STORE/dp/B017L0DEJ0?th=1 Thoughts? Link to comment https://bolterandchainsword.com/topic/350828-best-way-transport-a-lance-of-4-knights/ Share on other sites More sharing options...
frosteldar Posted October 26, 2018 Share Posted October 26, 2018 This site has lots of nice foam transport options, including for knights: https://us.battlefoam.com/ Link to comment https://bolterandchainsword.com/topic/350828-best-way-transport-a-lance-of-4-knights/#findComment-5179731 Share on other sites More sharing options...
Guest uk_crow Posted October 26, 2018 Share Posted October 26, 2018 I had a look at those and the tallest tray they do is too low if the knights have carapace weapons unfortunately... Link to comment https://bolterandchainsword.com/topic/350828-best-way-transport-a-lance-of-4-knights/#findComment-5179764 Share on other sites More sharing options...
Focslain Posted October 26, 2018 Share Posted October 26, 2018 This site has lots of nice foam transport options, including for knights: https://us.battlefoam.com/ I had a look at those and the tallest tray they do is too low if the knights have carapace weapons unfortunately... Technically the 4' trays will fit a knight if you have not glued the hip joint together and magged the carapace weapons. If you did then transporting the knights becomes much harder. Those trays are how i transport mine, as a side note the 4' trays also fit 3 armigar as long as you have not glued the carapace weapon on. Fixing the carapace weapons to be magged is not hard. I'll get the size I use because they fit right into the hole where the weapons go into to. And if you keep your polarities straight you'll be able to swap the weapons with ease. This also applies to the Dominus classes as well. Link to comment https://bolterandchainsword.com/topic/350828-best-way-transport-a-lance-of-4-knights/#findComment-5179820 Share on other sites More sharing options...
CommodusXIII Posted October 27, 2018 Share Posted October 27, 2018 I wrap mine in tissue paper, like Christmas ornaments, and stuff them in a cardboard banker's box. Three years of driving around to different events and not a single broken piece. Link to comment https://bolterandchainsword.com/topic/350828-best-way-transport-a-lance-of-4-knights/#findComment-5180049 Share on other sites More sharing options...
Shinespider Posted October 27, 2018 Share Posted October 27, 2018 I'm going to second Commodus. When transporting models, the main fear for me is small antennae and othersuch tiny bits snapping off. Knights are big, burly models without any delicate parts sticking out. The only really breakable thing is the dangling crotch banner, but that bit's location between the legs makes it unlikely that another knight would press into it. If you have four Knights standing upright in a box, a minimal amount of buffer between them (paper, bubble wrap, whatever) will do you just fine. Link to comment https://bolterandchainsword.com/topic/350828-best-way-transport-a-lance-of-4-knights/#findComment-5180140 Share on other sites More sharing options...
Guest uk_crow Posted October 29, 2018 Share Posted October 29, 2018 These are great suggestions, I spent an hour in a hardware store this weekend looking at boxes Link to comment https://bolterandchainsword.com/topic/350828-best-way-transport-a-lance-of-4-knights/#findComment-5180887 Share on other sites More sharing options...
Vel'Cona Posted October 29, 2018 Share Posted October 29, 2018 What are people’s experiences with the GW crusader case? Someone I have spoken to says they move 4 knights in theirs but I’m slightly skeptical... I'm not sure about the GW cases personally, but I have a friend that swears by them. I think transporting unmagnetized Knights will always be a challenge, though for my purposes I use a $8 plastic movable filing box for my single completed Knight, with a small inset of shipping foam. Link to comment https://bolterandchainsword.com/topic/350828-best-way-transport-a-lance-of-4-knights/#findComment-5180937 Share on other sites More sharing options...
Khulu Posted October 29, 2018 Share Posted October 29, 2018 I have a crusade case and I hate it. It's fine for infantry but vehicles and stuff are not ideal fits. All my onagers lost antennae from it and Knights may not fit at all if it's not in pieces. Link to comment https://bolterandchainsword.com/topic/350828-best-way-transport-a-lance-of-4-knights/#findComment-5180969 Share on other sites More sharing options...
frosteldar Posted October 29, 2018 Share Posted October 29, 2018 Otherwise, using some soft foam from a craft store and a plastic tub/crate should work well. Just put the foam around the inside of the box and between knights. Link to comment https://bolterandchainsword.com/topic/350828-best-way-transport-a-lance-of-4-knights/#findComment-5180982 Share on other sites More sharing options...
