Daemon prince conversions
Yeah, probably. That thing is the size of a Daemon Primarch, and is basically two times the size of the daemon prince. The base footprint would be far larger too; the ancient kit is supplied with a 105mm base, and daemon princes come with 60mm bases.
Perhaps use it as a greater daemon?
  • 3 weeks later...
Most likely there would be no problem fielding him as either at a tournament. Check with TO but rule of cool trumps "suggested" base size in my experience. Make sure your army is consistent and explain everything before setting up and blow em away with your awesome conversion!
