Spear of Achilles Posted November 15, 2018 Share Posted November 15, 2018 So, the Chaos marine Lord of Terror warlord makes a foe roll two dice and take the high for morale checks. Does 'And they shall know no Fear' require both dice to be re-rolled, or can the loyalist unit just re-roll one of the dice (the highest)? Link to comment https://bolterandchainsword.com/topic/351210-lord-of-terror-warlord-trait-vs-atsknof/ Share on other sites More sharing options...
Slasher956 Posted November 15, 2018 Share Posted November 15, 2018 It will be re-roll both. ATSHKNF (as far as I know) reads that you re-roll failed morale checks. The Lord of Terror trait says take the check on 2 dice picking the highest result, so there fore you basically ignore the first result and re take the test rolling 2 dice. Link to comment https://bolterandchainsword.com/topic/351210-lord-of-terror-warlord-trait-vs-atsknof/#findComment-5192044 Share on other sites More sharing options...
Khulu Posted November 15, 2018 Share Posted November 15, 2018 It will be re-roll both. ATSHKNF (as far as I know) reads that you re-roll failed morale checks. The Lord of Terror trait says take the check on 2 dice picking the highest result, so there fore you basically ignore the first result and re take the test rolling 2 dice. Not quite so, ATSKNF says you CAN reroll failed morale tests. So you would reroll both dice (not just one) but you don't have to. Link to comment https://bolterandchainsword.com/topic/351210-lord-of-terror-warlord-trait-vs-atsknof/#findComment-5192071 Share on other sites More sharing options...
