Plastic nob bikerz?
Quixus
If you're building a unit of Warbikers, you can save the Nob torsos from those kits and build Nob bikers that way. 6 biker kits will get you a 12-boy biker unit and a 6-Nob nob biker unit. Of course, the issue with this is that the warbiker unit is not missing it's nob, and you probably want more than 6 nob bikers. But it's an option that doesn't have waste.
Alternative, as CardinalVirtue pointed out, converting a unit of nob bikers out of the warbiker kit and the nob kit is doable. The Nob bodies come with legs already attached to the torso, so there would have to be some cutting and moving/replacing, but i wouldn't think it's too difficult a job.
I was wondering what ideas you have to make a a unit of nobz on warbikes without having to sell a kidney to get the forgeworld kit.
Thanks in advance
depending on where you live there are ebay bitz stores. If you have warbikers you aren't using you can order Biker nob torsos and Nobz heads and hand weapons. I have loads of them I got second hand that are basically just that. Sadly I've never used them. Maybe this edition I will.
I did it with warbiker kits and the nob torsos from boyz boxes. The boyz nob torsos are smaller than separate nobs, making them work nicely with the bikes. If you want an arm on the steering then you'll have to convert beyond the one nob arm per warbiker kit, but I for me three out of six nobs aren't steering their bikes. They're orks after all, smashin' & shooting' > steering!
