MasterHQ Posted December 2, 2018 Share Posted December 2, 2018 Using the following situation as a guide, I would like to know if I can assault after popping smoke. Ironclad dreadnought in a drop pod lands 9 inches from target. Being equipped with 2 heavy flames it cant shoot the target, so it pops smoke to increase survivability. Can I charge in the following charge sub-phase? If I do charge, does the -1 to hit affect the enemies overwatch? Thanks Link to comment https://bolterandchainsword.com/topic/351750-smoke-launchers-and-charging/ Share on other sites More sharing options...
Panzer Posted December 2, 2018 Share Posted December 2, 2018 Yes you can and no it wouldn't since no modifiers affect Overwatch unless explicitly mentioned. Link to comment https://bolterandchainsword.com/topic/351750-smoke-launchers-and-charging/#findComment-5204315 Share on other sites More sharing options...
Quixus Posted December 2, 2018 Share Posted December 2, 2018 Yes to both. Link to comment https://bolterandchainsword.com/topic/351750-smoke-launchers-and-charging/#findComment-5204316 Share on other sites More sharing options...
Kallas Posted December 2, 2018 Share Posted December 2, 2018 Yes to both. No, modifiers do not affect overwatch unless they specifically mention it. Eg, Imperial Guard Mordian Doctrine. Link to comment https://bolterandchainsword.com/topic/351750-smoke-launchers-and-charging/#findComment-5204714 Share on other sites More sharing options...
Quixus Posted December 2, 2018 Share Posted December 2, 2018 Yes to both. No, modifiers do not affect overwatch unless they specifically mention it. Eg, Imperial Guard Mordian Doctrine. yeah you are right on the modifiers. Weird that charging from cover does not give any benefit on overwatch. Link to comment https://bolterandchainsword.com/topic/351750-smoke-launchers-and-charging/#findComment-5204754 Share on other sites More sharing options...
Kallas Posted December 2, 2018 Share Posted December 2, 2018 yeah you are right on the modifiers. Weird that charging from cover does not give any benefit on overwatch. Cover does have an effect, because that modifies the save of the unit making the save rolls. Negative hit modifiers don't function, because overwatch says they don't (unless they specifically call out working in overwatch). Link to comment https://bolterandchainsword.com/topic/351750-smoke-launchers-and-charging/#findComment-5204836 Share on other sites More sharing options...
Slasher956 Posted December 3, 2018 Share Posted December 3, 2018 Using the following situation as a guide, I would like to know if I can assault after popping smoke. Ironclad dreadnought in a drop pod lands 9 inches from target. Being equipped with 2 heavy flames it cant shoot the target, so it pops smoke to increase survivability. Can I charge in the following charge sub-phase? If I do charge, does the -1 to hit affect the enemies overwatch? Thanks just an aside.. doesnt matter what ranged weapons you have you cant use them & smoke launchers in the same turn Link to comment https://bolterandchainsword.com/topic/351750-smoke-launchers-and-charging/#findComment-5205263 Share on other sites More sharing options...
Panzer Posted December 4, 2018 Share Posted December 4, 2018 Using the following situation as a guide, I would like to know if I can assault after popping smoke. Ironclad dreadnought in a drop pod lands 9 inches from target. Being equipped with 2 heavy flames it cant shoot the target, so it pops smoke to increase survivability. Can I charge in the following charge sub-phase? If I do charge, does the -1 to hit affect the enemies overwatch? Thanks just an aside.. doesnt matter what ranged weapons you have you cant use them & smoke launchers in the same turn Pretty sure he knows that hence why he popped smoke after realising he wouldn't be in range with his flamers anyway. ;) Link to comment https://bolterandchainsword.com/topic/351750-smoke-launchers-and-charging/#findComment-5205898 Share on other sites More sharing options...
