Bases for tanks
apologist
Rhino.
Land Raider.
A Rhino fits comfortably on a 120x92 mm base, the Land Raider would require a custom base, as it's too large to fit on a 170x105mm (Knight Base) at all (too wide, and too long).
I just checked, as I had both those base sizes handy, as I'm still painting a friend's Knight Castellan :lol:
Since they are not supposed to be on bases you can do pretty much whatever you want. You can do anything from barely fitting the model (like the old marines on 25mm bases) or create a whole landscape around it. The larger you make the base however the more impractical the model will be in play.
