Axineton Posted December 12, 2018 Share Posted December 12, 2018 Just wondered if decals can be removed and replaced if they’ve been on minis for a while? If so how does one go about doing it without making a mess of it? Link to comment https://bolterandchainsword.com/topic/352299-removing-decals-is-it-possible/ Share on other sites More sharing options...
NovemberIX Posted December 12, 2018 Share Posted December 12, 2018 I'm wiling to bet someone else will know a better way, but I generally scrape very carefully, just enough to remove the top decal layer, but not so much I start scraping the model underneath, drawback is that it's very easy to mess up. Link to comment https://bolterandchainsword.com/topic/352299-removing-decals-is-it-possible/#findComment-5214167 Share on other sites More sharing options...
Axineton Posted December 12, 2018 Author Share Posted December 12, 2018 Yeah that was one the ways I was thinking it could be done and probably last resort Link to comment https://bolterandchainsword.com/topic/352299-removing-decals-is-it-possible/#findComment-5214168 Share on other sites More sharing options...
Spaced Hulk Posted December 12, 2018 Share Posted December 12, 2018 Micro Set can be used to remove decals (as well as putting them on in the first place of course). Will only work if they're not sealed in place though. Link to comment https://bolterandchainsword.com/topic/352299-removing-decals-is-it-possible/#findComment-5214181 Share on other sites More sharing options...
Razblood Posted December 13, 2018 Share Posted December 13, 2018 White spirits, mineral spirits should do it and as long as you varnished under the decal it shouldn't ruin the paint. Link to comment https://bolterandchainsword.com/topic/352299-removing-decals-is-it-possible/#findComment-5214516 Share on other sites More sharing options...
