Foam trays for PM recommendations
Bloody Legionnaire
My fellow rotten brothers, I'm searching for some good storage for my PMs. Anyone have any recommendations on foam trays that fit PM sized models? I've found some on battlefoam but they are pretty expensive. Any other brands out there I should be aware of?
https://bolterandchainsword.com/topic/352367-foam-trays-for-pm-recommendations/
I got a KR Multicase set for my Deathguard Army.
1x K1-B (Bespoke) - V1H, D2H, 2xSM60 in Dark Pink
SM60 will store 25 models each on bases up to 32mm, it's a bit of a squeeze vertically (relative to the miniature, not the case) but these can accomodate the new Plague Marines.
D2H can be plucked in a few different ways. I'm using paired channels for terminator size models and the large characters like my Plaguecaster and Blightbringer, with single channels plucked for some of my Plague Marines.
V1H is a full depth pluck foam solution, which, with some magnetisation and creative tetris-ing of models, I think I should be able to fit a Plagueburst Crawler, Daemon Prince with Wings, Predator, Foetid Bloat Drone and a Myphitic Blight Hauler.
These, with the Standard K1 card case inside of a K1-B water resistant outer case came to £56.98. I've got a 2000 point list that I should easily be able to fit inside this case, which will also carry my books etc.
KR make a lot of different types of tray, and different sized cases too, so you can mix and match to fit your model collection.
