Doom Herald Posted December 16, 2018 Share Posted December 16, 2018 I've been trying to assemble my Blackstone Fortress rogue psykers but can't seem to get the front and back pieces to meet on the model's right side. Particularly, the issue is on the shoulder and the bottom of the cloak. Anyone having similar issues and find how to deal with it? I've already removed excess plastic, I've even cut down the pin like piece that holds them together to see if that's it, but no luck. The middle piece I'm using is the one that has the psykrs holding the Chaos star up, if that helps. Link to comment https://bolterandchainsword.com/topic/352406-blackstone-fortress-psykers-assembly-issue/ Share on other sites More sharing options...
Nemerax Posted December 17, 2018 Share Posted December 17, 2018 I had no issues with it, last time I had this was with FW stuff. Could you post a picture please? Link to comment https://bolterandchainsword.com/topic/352406-blackstone-fortress-psykers-assembly-issue/#findComment-5217488 Share on other sites More sharing options...
Doom Herald Posted December 19, 2018 Author Share Posted December 19, 2018 I found the issue. There was some extra plastic on the middle piece I missed. That's what I get for working on it late at night. Link to comment https://bolterandchainsword.com/topic/352406-blackstone-fortress-psykers-assembly-issue/#findComment-5219499 Share on other sites More sharing options...
Canadian_F_H Posted December 19, 2018 Share Posted December 19, 2018 Happens to all of us. Glad you got it figured out. Link to comment https://bolterandchainsword.com/topic/352406-blackstone-fortress-psykers-assembly-issue/#findComment-5219500 Share on other sites More sharing options...
Nemerax Posted December 20, 2018 Share Posted December 20, 2018 Interesting though. Mine were so perfectly and tight and I did not have to glue them and I could not disassemble what I once put together. On that point GW has improved a lot over the past decades. You should tell the customer service about the issue, they are quite forthcoming these days. I once ordered a Baneblade, but the hull was warped and so I went to the customer service and told them. I got a replacement for free, but warped too, so they kept sending Baneblades, till the 4th one was ok. I got to keep all of them, quite a lot of Lord of Wars now, as you can see in the ETL thread. Link to comment https://bolterandchainsword.com/topic/352406-blackstone-fortress-psykers-assembly-issue/#findComment-5219684 Share on other sites More sharing options...
