wako1302 Posted December 19, 2018 Share Posted December 19, 2018 Recently I have been struggling with 1st turn dakka. I play with 3 units of 16 Genestealers (usually at the front of my Army) with Flyrants, Hive Guard, etc behind them. But sometimes when it comes to my 1st turn the Genestealers are only a faction of their starting size. Is the solution to put hormogants or termagants up front just to soak the fire, or can my opponent choose to shoot over these at teh Genestealers anyway. What are othe people doing ? Link to comment https://bolterandchainsword.com/topic/352484-1st-turn-dakka/ Share on other sites More sharing options...
Dont-Be-Haten Posted December 19, 2018 Share Posted December 19, 2018 I personally forgo Gene stealers because they are such easy targets. Even with a 5++ they die in droves. What I would do however is take a malanthrope or venomthropes to -1 your opponent's dakka. The Malantheope is the best option since it has 9 wounds and is a character. The 3" bubble is extremely useful. Link to comment https://bolterandchainsword.com/topic/352484-1st-turn-dakka/#findComment-5219261 Share on other sites More sharing options...
Azekai Posted December 19, 2018 Share Posted December 19, 2018 Malanthropes are great, but also, as cliche as it sounds, get more LoS blocking terrain. Keep the 'stealers out of sight if at all possible (and it should be possible). If not, get new/different terrain. Link to comment https://bolterandchainsword.com/topic/352484-1st-turn-dakka/#findComment-5219449 Share on other sites More sharing options...
BrassClaw Posted December 22, 2018 Share Posted December 22, 2018 The way I use my genestealers is with a Trygon(or trygon prime if you have the points). Take a group of 20 genestealers via Subterranean assault. That gives you 9 inches to assault a juicy target and take hivefleet behemoth for a reroll that charge if you like. It's a little pricey, I wouldn't do with more than 2 trygons, but i have pulled it off a few times Link to comment https://bolterandchainsword.com/topic/352484-1st-turn-dakka/#findComment-5220961 Share on other sites More sharing options...
Xenith Posted December 26, 2018 Share Posted December 26, 2018 If you take all of your LOS blocking terrain, does it cover a full time of a realm of battle board when you're on a 6*4 table? That's the recommended amount, as I recall. Link to comment https://bolterandchainsword.com/topic/352484-1st-turn-dakka/#findComment-5223168 Share on other sites More sharing options...
