Alternative Daemon Princes.
I would suggest giving Creature Caster a look. They have some cool alternatives for daemon models.
Personally I like the King of War model which would fit you Khorne theme. Although I believe hes bloodthister size
You might want to also look at the Lord of Slaughter, Lady of Strife or the Lord of Malice
I use a balrog with daemon prince arms (magnetized for options) and DP armor bitz on the shoulders and legs.  The extended wings give him a much bigger profile, but with the character rule this edition it's not a significant issue.  He gets a lot of good comments :)
I use a balrog with daemon prince arms (magnetized for options) and DP armor bitz on the shoulders and legs.  The extended wings give him a much bigger profile, but with the character rule this edition it's not a significant issue.  He gets a lot of good comments :smile.:
I converted a sons of horus contemptor into an iron warriors khornate daemon prince with the fleshmetal exoskeleton and two claws.
Pics or it didn't happen. :wink:
Creature Caster kits look good but they're a bit big for DP size. Any ideas for putting wings on a Khorgorath?
Aren't they a bit too big (and expensive) for a daemon prince?
Morghasts look cool as Thousand Sons DPs, and if you want too they are even cheaper than the normal model.
Creature Caster:
Lord of Slaughter
Lady of Strife
Lord of Malice (Technically undivided but who cares)
Titan Forge:
Lord of Fury
Mierce Miniatures:
Great Axe Malacant
Infernii (this contains all variants, although the big ones would be for bloodthirsters)
Limbo Miniatures:
Demon Vanguard (Out of stock atm)
Alternatively, if you only want wings:
Wargame Exlusive 1
Wargame Exlusive 2
Kromlech
Great selection there krakjen, cheers. I really like the Mierce minis, any idea of size comparison?
You can use the base size as a reference for a rough estimation.
For the one I linked for example, it's a 100mm wide base.
I found this picture for a comparison with a 40K mini:
Here's a few of my princes:
For my two flying princes, a main goal of them was to make them compact and transportable. One of my biggest pet-peeves is models with giant stupid wings.
http://mcgibs.com/wp-content/gallery/miniatures/chaos_cacoprince01.jpg
Cacodaemon: Pingpongball, lots of greenstuff, and bits. The face is from the WFB Chaos Chariot
http://mcgibs.com/wp-content/gallery/miniatures/chaos-juggerlord01.jpg
Minotaur foot prince. WFB Cryptfiend, minotgaur head, and some ork and ogre bits. Horns/helmet is also from the Chaos Chariot.
http://mcgibs.com/wp-content/gallery/miniatures/chaos-bloodpuncher06.jpg
http://mcgibs.com/wp-content/gallery/miniatures/chaos-bloodpuncher02.jpg
Punchy prince. AOS Kogorath(?), bloodthirster head, plastic daemonprince wings, and WFB Ghorgon fists.
I don't have any of it's construction, unfortunatly. I have these primed shots though.
http://mcgibs.com/wp-content/gallery/workbench/chaos-cacowip01.jpg
http://mcgibs.com/wp-content/gallery/workbench/chaos-cacowip02.jpg
(I had a few extra pipes and stuff added on)
And the early stages of Mr. Punchy
http://mcgibs.com/wp-content/gallery/workbench/chaos-punchy.jpg
Personally, the plastic Daemon Prince kit is one of the best GW has ever made. It is so versatile, and with a little creativity, it is a perfect base for customizing your own Prince.
Here are some of mine
Bog standard with a Defiler mask
Okbok B'Gok, Daemon Prince of Tzeentch
And a Daemon Prince using greenstuff and a ton of extra bits out of my bitzbox
All you need is a Daemon Prince kit, a little imagination, and a handful of different bits.
