ShadowCore67 Posted December 30, 2018 Share Posted December 30, 2018 This may be an obvious answer but I just wanted to double check. Meticulous Uprising can only be used once per turn correct? Link to comment https://bolterandchainsword.com/topic/352737-meticulous-uprising-question/ Share on other sites More sharing options...
Lord Marshal Posted December 30, 2018 Share Posted December 30, 2018 Correct. You can't use a stratagem again in the same phase and Cult Ambush is done at the end of the movement phase. Link to comment https://bolterandchainsword.com/topic/352737-meticulous-uprising-question/#findComment-5225188 Share on other sites More sharing options...
Cognative Posted December 30, 2018 Share Posted December 30, 2018 Correct. You can't use a stratagem again in the same phase and Cult Ambush is done at the end of the movement phase. This is true for Matched Play. Open or Narrative or whatever it's called does not have the rule of only using a strategem once per turn Link to comment https://bolterandchainsword.com/topic/352737-meticulous-uprising-question/#findComment-5225202 Share on other sites More sharing options...
Marshlands Posted December 31, 2018 Share Posted December 31, 2018 As of Big FAQ 2 it can basically be used twice in matched play, once on turn 2 and once on turn 3 Hopefully the codex will have some alternatives to work with Link to comment https://bolterandchainsword.com/topic/352737-meticulous-uprising-question/#findComment-5225587 Share on other sites More sharing options...
Arson Fire Posted December 31, 2018 Share Posted December 31, 2018 As of Big FAQ 2 it can basically be used twice in matched play, once on turn 2 and once on turn 3 Hopefully the codex will have some alternatives to work with Well, you can use Return to the Shadows on a unit, then Meticulous Uprising it back in past turn 3. Link to comment https://bolterandchainsword.com/topic/352737-meticulous-uprising-question/#findComment-5225689 Share on other sites More sharing options...
Marshlands Posted January 1, 2019 Share Posted January 1, 2019 As of Big FAQ 2 it can basically be used twice in matched play, once on turn 2 and once on turn 3 Hopefully the codex will have some alternatives to work with Well, you can use Return to the Shadows on a unit, then Meticulous Uprising it back in past turn 3. I stand corrected, twice with a primus then once a turn Link to comment https://bolterandchainsword.com/topic/352737-meticulous-uprising-question/#findComment-5225923 Share on other sites More sharing options...
