Datasheets across Codices the same?
I'm not sure if there is a definitive answer, unfortunately.
My opinion is that, in this specific example, they are the same datasheet; they are identical in all regards except that in Codex:BA, the <CHAPTER> keyword field is already assigned to Blood Angels.
That's what I feel exactly, but - a better example maybe - I'd like to field 4 Librarians, 2 Ultramarines and 2 Blood Angels.
They have different disciplines! That's set in the Datasheet, but they're the same otherwise. So it's not just the keyword that differentiates those two.
Nothing like that with Captains though.
So are their Sheets identical while the Libbys' aren't?
Geez, GW, what are the FAQs for?
Really? Only 8th ed ‘dex I have is C:Space Marines, so I can’t actually look, but are you sayjng that someone playing Angels Vermillion or Blood Drinkers (for example) would not be able to change the Keyword to match their actual chapter name?
You still can, the Codex just presumes you will use the <Blood Angels> keyword, and instructs you to replace it with the successor chapter of your choosing if you wish.
I only mentioned it because it's the only text distinction between the SM and BA datasheets.
It's not just about keywords. Individual Datasheets have a name. So if the Daemon Prince Datasheets have different names and that's the reason for counting as different Datasheets that's a very important piece of information since the Captain Datasheets all have the same name.
They never mention that it is because of the name. Otherwise, the answer probably would be: "Yes, because they are named differently".
The real difference is these models have access to different special rules, stratagems, relics,  they grant bonuses to different types of units, etc. Pretty much the same as Captains do.
I don't know that that's actually true for Captains though, because the special rules described on the datasheets (And They Shall Know No Fear, Rites of Battle, Iron Halo, Storm Shield, Jump Pack Assault) are identical in both books, and the only reason they gain access to different tactics, relics and stratagems etc is due to the chapter keyword being different.
Chapter Keywords on their own aren't a basis to say the datasheets are different, because otherwise you could make the argument that Ultramarine and Imperial Fists captains have different datasheets, even though they are selected from the same entry in the same book.
