'Clean' transparent glue?
Azekai
Howdy folks, I recently ordered some kits with translucent/clear components. My normal gorilla glue superglue is strong but almost always leaves behind a frosty residue that is basically impossible to disguise without painting the plastic. What are some good brands available in the US that set 'cleanly' and wouldn't mess up the see-through nature of the plastic?
https://bolterandchainsword.com/topic/352878-clean-transparent-glue/
Most canopy glues are basically just strong PVA, so you may already have a suitable woodglue PVA. Craft PVA aimed at paper though is usually too dilute for a decent hold. Easy to clean up with a damp finger/q-tip.
Because of the different plastics, poly cement can cause warping and fogging, and CA risks fogging unless applied in very small amounts in a fine seam.
I've seen a number of people recommend zap 560 and gs-hypo cement (bit cheaper!) if you don't have a suitable PVA.
