3000 Militia
I picked up a bunch of R&H upgrade sets when they went on LCTB and I’ve been trying to figure out what I want to do with them that’ll be able to hold its own against Astartes and Mechanicum lists. Here’s what I’ve come up with; it could certainly be run Loyalist, but I’ll be running it as a Traitor for Rule of Cool.
The theory is that I have two blobs that want to be in melee rushing forward. They’ll die, tie up something shooty, or the Discipline Master will Melta Bomb something eventually. Then I have 2 Infantry Squads for objective scoring. They’re not terribly sturdy, but they’re also not terribly threatening. A Drill pops up in my opponent’s backfield with 8 Multimeltas. I’ve considered maybe using plasma fusils here instead? I could drop the Fire Support Squad and apply Merchant Princeling to the Plasma Fusils instead. The Sentinels probably outflank to be annoying later in the game. Then I have a Baneblade on one side, two Malcadors on the other, and 3 Medusa Batteries holding the middle. Thoughts?
Crusade (Imperialis Militia and Cults Army List)
HQ
Discipline Master Cadre (Frenzon Dispensers)
2x Discipline Master (Augmented Weapon, Melta Bombs, Needle Pistol, Refractor Field)(Infantry Squads)
Discipline Master (Augmented Weapon, Laspistol, Melta Bombs, Refractor Field)(Fire Support or Heavy Ordnance)
2x Discipline Master (Laspistol, Melta Bombs, Power Weapon, Refractor Field)(Inducted Levy Squads)
Force Commander (Cyber-familiar, Infravisor, Planetary Overlord)(goes with Fire Support or Heavy Ordnance)
The Muster of Worlds (Alchem-jackers, Cyber-augmetics) Warlord Trait: Merchant Princeling applies to Fire Support Squad
Elites
Enginseer Auxilia (goes in Termite)
Enginseer Adept (Augury Scanner, Infravisor, Meltabombs, Nuncio-vox)
Enginseer Adept (Meltabombs)
8x Servo-automata (Multi-melta)
Medicae Detachment
3x Medicae Orderly
Troops
Fire Support Squad
7x Militia Fire Teams (Missile Launcher with Frag and Krak)
Inducted Levy Squad (Auxilia Pistols, Frag grenades, Frenzon Dispensers, 49x Levy Auxiliaries)
Infantry Squad
Infantry Squad
Fast Attack
Sentinel Scout Squadron
3x Auxilia Sentinels (Autocannons)
Terrax Pattern Termite Assault Drill
Selections: 2x Heavy Flamer
Heavy Support
Heavy Ordnance Battery
3x Artillery Carriage Team (4x Militia Auxilia Crew, Medusa Siege Guns)
Malcador Heavy Tank (Armoured Ceramite, Autocannons, Battle Cannon, Demolisher Siege Cannon, Flare Shield, Siege armour)
Lords of War
Baneblade Super-heavy Battle Tank (Armoured Ceramite, 2x Side sponson with one Lascannon and one twin-linked Heavy bolter, Super-heavy Command Tank)
https://bolterandchainsword.com/topic/352966-3000-militia/
They’ll probably ally with a Legion sometimes, but I wanted a base to build to that would also work on its own.
Where does it say cyber augmetics don’t get FNP? I don’t see that in either the cyber augmetics or medic rules. I’m looking at the iBooks version, I don’t have a hard copy.
I’ve looked longingly at the Thunderbolt, but I already own the Sentinels, and the Thunderbolt is $$$. Maybe drop the Sentinels and one of the Medusa carriages? I only own one of those atm, and I’m concerned about their effectiveness. Two Medusas would also be easier to hide out of LOS.
https://bolterandchainsword.com/topic/352966-3000-militia/#findComment-5233935
Nevermind, I got it confused with gene crafted.
The great thing about the militia is that you don't really need to use the FW models. My thunderbolt was built from the corvus blackstar kit.
The problem with artillery batteries is that they can't split fire, 3 guns on one target is overkill imo
https://bolterandchainsword.com/topic/352966-3000-militia/#findComment-5233955
