Quixus Posted January 9, 2019 Share Posted January 9, 2019 Where can I find that nifty chart that says, if a wargear unit exists on the index unit, you can use it with the codex unit e.g. Combi melta on a Thousand Sons Sorcerer in TDA? Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/ Share on other sites More sharing options...
N1SB Posted January 9, 2019 Share Posted January 9, 2019 Great question, I think you mean the Developer's Commentary of 40k and it's in the Warhammer Community's FAQ section, and it's right here: https://whc-cdn.games-workshop.com/wp-content/uploads/2017/11/warhammer_40000_designers_commentary_en-1.pdf And it's this one I think you mean. Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5231781 Share on other sites More sharing options...
Quixus Posted January 9, 2019 Author Share Posted January 9, 2019 Thanks Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5231791 Share on other sites More sharing options...
Ciler Posted January 10, 2019 Share Posted January 10, 2019 Side question. If I use a datasheet from the index (say a space marine character on bike), do I also use the index for points ? This is relevant if (for instance) the model is equipped with a power fist which is now sizeably cheaper in the codex. Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5232243 Share on other sites More sharing options...
Quixus Posted January 10, 2019 Author Share Posted January 10, 2019 Is the point cost a rule? I think so. Use the points from the codex as the chart says. Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5232274 Share on other sites More sharing options...
Brother Casman Posted January 10, 2019 Share Posted January 10, 2019 Given that points are regularly reviewed and revised in Chapter Approved, I would go with the latest published points costs. Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5232278 Share on other sites More sharing options...
Quixus Posted January 10, 2019 Author Share Posted January 10, 2019 Of course, that's what I meant. Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5232282 Share on other sites More sharing options...
brother Vorn_GarDos Posted January 15, 2019 Share Posted January 15, 2019 i want to be sure of something. i have a 2nd edition marneus calgar. Is it legal to use him still in games (non-tournament)? Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5235056 Share on other sites More sharing options...
Slasher956 Posted January 15, 2019 Share Posted January 15, 2019 Why wouldn’t he be? Large chunks of peoples armies are 2nd ed models .... 90% of mine are 3rf Ed Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5235148 Share on other sites More sharing options...
Leonaides Posted January 15, 2019 Share Posted January 15, 2019 He is quite definately Marneus Calgar so yes - though you probably wouldnt be able to use him as Primaris Calgar. I cant remember if the Index Astartes had rules for Calgar not in terminator armour, so you might have to use those rules, rather than his power armour rules (i assume thats the one you are talking about, not the guy on a chair/toilet). Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5235307 Share on other sites More sharing options...
chapter master 454 Posted January 16, 2019 Share Posted January 16, 2019 Ok so I have a further question that could be asked within the same context of this thread then. Tau have the hammerhead both in the codex and forge world index and their points are correct (both are the same costs) HOWEVER the forge world hammerhead (or one of them) can take high yield missile pods. In the forge world index, those codex 41 per where as in the codex they are 25 points per. As per what is stated here hold true for points and thus we use points that exist within the codex or the index of forge world? This chart would say use the codex for points (which would be 25) AND within chapter approved 2018 when referring to what points to use, it even states the most recent publication of the rules for those pieces of gear (again, that would be the codex). Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5236098 Share on other sites More sharing options...
Slasher956 Posted January 16, 2019 Share Posted January 16, 2019 I'd email the FAQ team as its most likely they 'missed it off' the list of forgeworld TAU weapons. After all CA2018 brought all the Craftworld weapons costs in to line with the Codex. Personally I'd use the codex cost as thats the common published book Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5236175 Share on other sites More sharing options...
Panzer Posted January 17, 2019 Share Posted January 17, 2019 Not a direct answer to the question but it indicates that FW units always use the latest versions of things that you also use for the Codex: Q: Can I use the weapon profiles for things like lasblasters andD-cannons from Codex: Craftworlds, or do I have to use theones printed in Imperial Armour – Index: Xenos?A: You can use the profiles from Codex: Craftworlds. Q: Can I use the weapon profiles for things like deffkannons andsupa-gatlers from Codex: Orks, or do I have to use the onesprinted in Imperial Armour – Index: Xenos?A: You can use the profiles from Codex: Orks. Link to comment https://bolterandchainsword.com/topic/353026-index-vs-codex-units-and-wargear/#findComment-5236536 Share on other sites More sharing options...
