Guest Posted January 13, 2019 Share Posted January 13, 2019 I don't have either of these boxes, but what is their scale compared to normal cultists and each other. I have a bad feeling that BSF is much larger than either of the cultists. Link to comment https://bolterandchainsword.com/topic/353091-bsf-traitor-guard-and-dark-vengeance-cultist-scale/ Share on other sites More sharing options...
Guest Triszin Posted January 13, 2019 Share Posted January 13, 2019 I don't have either of these boxes, but what is their scale compared to normal cultists and each other. I have a bad feeling that BSF is much larger than either of the cultists. bsf traitors aren't that much larger than standard guard. they are on the old 40k slot bases. 25mm. Link to comment https://bolterandchainsword.com/topic/353091-bsf-traitor-guard-and-dark-vengeance-cultist-scale/#findComment-5233792 Share on other sites More sharing options...
Robbienw Posted January 13, 2019 Share Posted January 13, 2019 The BSF guard are quite tall, taller than stuff like cadians and scions. They are similar height to necromunda humans like the orlocks and van saar. I think this means they are taller than cultists, but have no cultist models to compare with. This link has a good comparison to cadian, scion and voidsman: https://scontent-sea1-1.cdninstagram.com/vp/3e87549da5b0825edd35024dbcfc3765/5C98014C/t51.2885-15/e35/s480x480/44538804_287001815257935_3676429072394861968_n.jpg?_nc_ht=scontent-sea1-1.cdninstagram.com Link to comment https://bolterandchainsword.com/topic/353091-bsf-traitor-guard-and-dark-vengeance-cultist-scale/#findComment-5233871 Share on other sites More sharing options...
Doghouse Posted January 13, 2019 Share Posted January 13, 2019 Next to the Trator Guard I have the plastic Cadians I bought a little while back look like really stumpy high grav worlders. The new guys are so not so much bigger as better proportioned which does make the two look out of place to me when stood next to each other. It's like using two models from two different companies to proxy. Link to comment https://bolterandchainsword.com/topic/353091-bsf-traitor-guard-and-dark-vengeance-cultist-scale/#findComment-5233917 Share on other sites More sharing options...
Robbienw Posted January 13, 2019 Share Posted January 13, 2019 They pretty much are designed by two different companies, given the amount of time between the two lol Link to comment https://bolterandchainsword.com/topic/353091-bsf-traitor-guard-and-dark-vengeance-cultist-scale/#findComment-5233945 Share on other sites More sharing options...
Panzer Posted January 13, 2019 Share Posted January 13, 2019 Next to the Trator Guard I have the plastic Cadians I bought a little while back look like really stumpy high grav worlders. The new guys are so not so much bigger as better proportioned which does make the two look out of place to me when stood next to each other. It's like using two models from two different companies to proxy. Give them heads with beards and call them squats. Link to comment https://bolterandchainsword.com/topic/353091-bsf-traitor-guard-and-dark-vengeance-cultist-scale/#findComment-5233974 Share on other sites More sharing options...
Tordeck Posted January 13, 2019 Share Posted January 13, 2019 Side by side the TG stand ~1-2mm taller than DV cultists. Mixed into one unit and its not really noticeable. Link to comment https://bolterandchainsword.com/topic/353091-bsf-traitor-guard-and-dark-vengeance-cultist-scale/#findComment-5234002 Share on other sites More sharing options...
Dracos Posted January 13, 2019 Share Posted January 13, 2019 You give me an Imperial Guard army those proportions then I'm defintiely making Guard my next army buy Link to comment https://bolterandchainsword.com/topic/353091-bsf-traitor-guard-and-dark-vengeance-cultist-scale/#findComment-5234090 Share on other sites More sharing options...
Panzer Posted January 13, 2019 Share Posted January 13, 2019 You give me an Imperial Guard army those proportions then I'm defintiely making Guard my next army buy *Points towards GSC* Link to comment https://bolterandchainsword.com/topic/353091-bsf-traitor-guard-and-dark-vengeance-cultist-scale/#findComment-5234134 Share on other sites More sharing options...
Kinstryfe Posted January 14, 2019 Share Posted January 14, 2019 Next to the Trator Guard I have the plastic Cadians I bought a little while back look like really stumpy high grav worlders. The new guys are so not so much bigger as better proportioned which does make the two look out of place to me when stood next to each other. It's like using two models from two different companies to proxy. Give them heads with beards and call them squats. :teehee: I suddenly have the notion that squats were never a separate abhuman strain, but just a slur used against guardsmen of below average height. That 5'7" recruit? Total squat. And to stay on topic, I really need to get like a million of the BSF guardsmen. They look phenomenal. Link to comment https://bolterandchainsword.com/topic/353091-bsf-traitor-guard-and-dark-vengeance-cultist-scale/#findComment-5234282 Share on other sites More sharing options...
Gederas Posted January 24, 2019 Share Posted January 24, 2019 Next to the Trator Guard I have the plastic Cadians I bought a little while back look like really stumpy high grav worlders. The new guys are so not so much bigger as better proportioned which does make the two look out of place to me when stood next to each other. It's like using two models from two different companies to proxy. Give them heads with beards and call them squats. I suddenly have the notion that squats were never a separate abhuman strain, but just a slur used against guardsmen of below average height. That 5'7" recruit? Total squat. And to stay on topic, I really need to get like a million of the BSF guardsmen. They look phenomenal. Iirc, the average height for a Guardsman IS 5'7" Also... Is.... Is it too hopeful that TRAITOR GUARD might be one of the things that's being teased in the 80 Days for Vigilus? Because remember: Warhammer Quest: Silver Tower had Kairic Acolytes, and then they were made as their own multipart kit afterwards. Link to comment https://bolterandchainsword.com/topic/353091-bsf-traitor-guard-and-dark-vengeance-cultist-scale/#findComment-5240940 Share on other sites More sharing options...
