Wassa Posted January 14, 2019 Share Posted January 14, 2019 I have an Emperors Fist Tank Company, and 3 Tank Commanders. I've selected Vigilus in the detachment section, and I've ticked Emperors Fist under each Tank Commander. But the option to select the Hammer of Sunderance doesn't appear unless I add a field commander or make on my warlord. This is a Battlescribe error right? I've reread the Vigilus Rules and it says any Character with the Emperors Fist keyword with a Battle Cannon should be able to take it? Link to comment Share on other sites More sharing options...
Wassa Posted January 14, 2019 Author Share Posted January 14, 2019 Solved it. You need to select *anyone* to be a warlord before the heirloom option will appear. Odd. Link to comment Share on other sites More sharing options...
sairence Posted January 14, 2019 Share Posted January 14, 2019 Yeah, it's an error currently, though a minor one as there's an easy work around. I'm sure it'll be fixed once there is time. :) Link to comment Share on other sites More sharing options...
Slasher956 Posted January 14, 2019 Share Posted January 14, 2019 Not really an error its just that no relics appear in BattleScribe unless there is a warlord selected ... reason why its not an error, you need a warlord of a faction to unlock the relics in the first place eg pg 99 of CA2018 says: If your army is led by an ADEPTA SORORITAS Warlord, then before the battle you may give one of the followingRelics of the Ecclesiarchy to an ADEPTA SORORITAS CHARACTER. Link to comment Share on other sites More sharing options...
Wassa Posted January 14, 2019 Author Share Posted January 14, 2019 Ah I never knew that! Thanks! Link to comment Share on other sites More sharing options...
