Horrors and Morale
My Thousand Sons have been recruiting some never born allies and a problem poses itself to me from the Daemon codex. If I have a blob of horrors and I set points aside to split them, how does morale work for them when they split?
If I have 30 pink horrors and 25 die, it seems like all the blues I spawn will just immediately run away. Am I missing something?
https://bolterandchainsword.com/topic/353224-horrors-and-morale/
Yes, the more you split at once the more will just run away. If using big squads and max split try for the banner if only a few died and othwrwise ALWAYS build your entire list around the assumption you are going to spend 2cp a turn to autopass until their dead/Not worth protecting. You need a few battalions basically.
If you're using a 2nd unit might be worth putting the 2nd in reserve
 * This
Not much else that can be done, besides having a nearby LOC to buff up the Ld.
*edit: You can always reserve a few pt's for blues or brims and have them be the models removed by failed morale, providing they were part of the unit at the start of the morale phase.
