Can Chaos use the Vindicator Laser Destroyer?
A friend used it in our narrative game, and I went to check for it, and I couldn't find in the forgeworld index.
Ran
You won't find it in the Chaos Index from Forgeworld, because they forgot to print it in there. Check the FAQ for Imperial Armour Index: Forces of Chaos:
Q: There is no datasheet for a Chaos Vindicator Laser Destroyer– is there a datasheet I should use for this model?
A: Use the Deimos Pattern Vindicator Laser Destroyer datasheet on page 8 of Imperial Armour Index: Forces of the Adeptus Astartes. It gains the Hellforged
keyword and must replace all of its Faction keywords with the following: Chaos, Heretic Astartes, <Mark of Chaos>, <Legion>. In addition, it gains the following ability:
Machina Malefica: At the end of each Fight phase, roll a number of D6 for this model equal to the number of models that were slain by it during this phase; for each dice that scores a 5+, this model regains one lost wound. This model cannot regain lost wounds by any other means.’
In addition, it gains the following weapon:
‘Weapon   Range   Type   S   AP   D   Abilities
Infernal Hunger Melee Melee User -3  1-’
