QQ about the GW Contemptor Kit
If you want the absolute maximum parts compatibility and poseability with the least amount of cutting and modifying of the base mini, then the Resin Dread is the one you want (helps that its also available in the varions Legion Variants).
Otherwise, its as Viridia says, the GW Contemptor arms are essentially a single, unposeable piece at its baseline. You'd have to saw of the weapon at basically the Shoulder/Elbow and modify the join area a bit on either the plastic arm or the resin weapon so that they can go together in a smooth way.
You can see it in the sprue image for the GW Contemptor:
Now, if you look at the Resin Multimelta, you can see that it would join in right below the Ballsocketed shoulderpad part of the Dreads arm:
99550101226_ContemptorPatternMultiMelta.
Hehehe....he said "Ballsocketed..."
Thanks, both of your. I had gathered as much intel as I could, but wanted to triple-confirm before spending FW prices on anything.
Thank again!
