Guest Triszin Posted January 21, 2019 Share Posted January 21, 2019 so I nabbed 2 tauroxs, well three. I'm in the process of doing a heavy conversion build on one turning it into a Armidillo APC from gears of war. The other 2 I will be converting into a pickup type taurox. that looks like a Samson from titanfall. The theme is going to be GEARS of WAR, COG and UIR soldiers. Taurox vehicles, Scions. so question: can anyone find a comparison picture of a catachan and a scion tempestus models? Im thinking of some simple convserion with some, putting catachan arms on a scion. Link to comment Share on other sites More sharing options...
WarriorFish Posted January 21, 2019 Share Posted January 21, 2019 The plastic Catachan Infantry Squad kit is old, and not great. The Command Squad box is not as old and is great, but as you'd expect a lot less arms in. The Scion torso is a bit bigger than the standard Guard torso though so maybe there's some wiggle room? Link to comment Share on other sites More sharing options...
crimsondave Posted January 21, 2019 Share Posted January 21, 2019 You probably want to take a look at the assembly instruction for the Scions. I've put together and painted a lot of guard and a fair number of Scions. The Scions assembly are somewhat different than regular guard. Probably not a big deal for what you want to do but I'd still get a look in advance before jumping into it. Link to comment Share on other sites More sharing options...
