Consolidation query
Always towards the nearest unit unless you have a rule that says otherwise.
Also keep in mind that only the unit you activated can consolidate. So if you have two units in melee with an opponent and destroy it with the first unit only the first unit can consolidate but not the second because you can't activate it anymore.
If there's no enemy units remaining then you've tables your opponent and the game ends.
Or all remaining enemy units are in reserves. In that case you can't consolidate in any direction and your opponent better bring his reserves in if he doesn't want to be tabled. :P
Also not every mission ends with the enemy getting tabled. The new CA18 missions continue for their full amount of turns even if one of the player got tabled.
Or all remaining enemy units are in reserves. In that case you can't consolidate in any direction and your opponent better bring his reserves in if he doesn't want to be tabled. :tongue.:
If both units charged the second unit would still get to activate in the fight phase but otherwise spot on.
Right, thanks for the correction! I keep forgetting that you can always activate a unit that charged this turn regardless of whether there's an opponent within 1" or not (only if the charge succeeded tho!).
