Evil Eye Posted January 22, 2019 Share Posted January 22, 2019 I received some Alclad paint for Christmas, including Holomatic Spectral Chrome, which gives a very pretty rainbow/hologram/CD-like effect (though I haven't used it yet as the weather is not overly friendly for airbrushing at the moment). Anyway, as with most of these special effect metallics it needs a gloss black base to truly work, much like the GSW chameleon paints. However, I had a thought; given that it's very translucent/thin, would using a gloss base of another colour instead of black give a different finish with a similar effect? For example, if I were to use the stuff over gloss white, would it give a finish more like pearl/opal than the CD surface/"rainbow chrome" you get with gloss black? Looking in the bottle you can see the effect even in the liquid, so I suspect it would have some results other than just not working. Having used the GSW paints on a white palette, the residue tends to dry in a pearl/opal look. Once I can airbrush again I'll run some experiments, but if anyone else has either tried it or knows the theory behind it then please do give your two cents. Link to comment https://bolterandchainsword.com/topic/353296-swapping-gloss-black-bases-for-gloss-white-with-metallics/ Share on other sites More sharing options...
