xenomortis Posted February 25, 2019 Share Posted February 25, 2019 Hi, I have been searching around but not come up with anything. Has anyone got any good alternatives or kit bashed anything in the shape of a dreadnought missile launcher? There is the forge world option or buy the standard dreadnought kit, but much prefer the price and aesthetics of the venerable which doesn't come standard with a missile launcher. Thanks! Link to comment https://bolterandchainsword.com/topic/354133-dreadnought-missile-launcher/ Share on other sites More sharing options...
KhorneHunter57x Posted February 25, 2019 Share Posted February 25, 2019 The missile pod from the AdMech Onager Dunecrawler is a bit blocky, and requires a little conversion to work (removing the AdMech cog on one side and covering the hole on the other), but it is the perfect size to use on a Dreadnought. EDIT: My AoBR Dreadnought with Ven Dread Plasma Cannon and Onager Dunecrawler Icarus Array Missile Launcher: (yes, I need to dust him...) Link to comment https://bolterandchainsword.com/topic/354133-dreadnought-missile-launcher/#findComment-5264021 Share on other sites More sharing options...
Exilyth Posted February 26, 2019 Share Posted February 26, 2019 I used the assault cannon arm (without assault cannon) and a ) a missile launcher from a sentinel b ) the missile launcher tip from a tactical/dev squad (w/firing missile) to build one (ven) dread ML arm each. I glued the left over arm armour bit on the bottom of the assault cannon arm, so the bit sits on top when the arm is turned around and used on the other side of the dread. And some milliput (yellow + grey) to fill the holes ofc. edit: obviously, this will not be an option for you if you intend to use the assault cannon. eidt2: just found some bitz in the bitz box - dreadnought close combat weapon arm shoulder and one of the old imperial guard hunter killer missiles (aka missile in a box). That combination would go together nicely too, but at the cost of a dreadnought close combat weapon arm. Link to comment https://bolterandchainsword.com/topic/354133-dreadnought-missile-launcher/#findComment-5264492 Share on other sites More sharing options...
Marshal Vespasian Posted February 28, 2019 Share Posted February 28, 2019 I got one printed buy a guy with a resin printer. There is a file for a dreadnought rocket launcher on thingiverse. Link to comment https://bolterandchainsword.com/topic/354133-dreadnought-missile-launcher/#findComment-5265660 Share on other sites More sharing options...
Grotsmasha Posted February 28, 2019 Share Posted February 28, 2019 I might have one I'm not using and don't need. Link to comment https://bolterandchainsword.com/topic/354133-dreadnought-missile-launcher/#findComment-5265705 Share on other sites More sharing options...
Xenith Posted February 28, 2019 Share Posted February 28, 2019 Hi, I have been searching around but not come up with anything. Has anyone got any good alternatives or kit bashed anything in the shape of a dreadnought missile launcher? There is the forge world option or buy the standard dreadnought kit, but much prefer the price and aesthetics of the venerable which doesn't come standard with a missile launcher. Thanks! Things you can do: replace forearm section of power fist army with Valkyrie rocket pod. Is a ML/Powerfist combo an option? That makes it easier, just use one of the right arms and stick some missile parts into the hole. Link to comment https://bolterandchainsword.com/topic/354133-dreadnought-missile-launcher/#findComment-5265712 Share on other sites More sharing options...
Elzender Posted February 28, 2019 Share Posted February 28, 2019 I started one using the extra armour plates that come in the venerable dread kit and a typhon missile launcher from the old DA ravenwing upgrade sprue. I did not finish it and it needed some more work to fill the gaps, but the basic idea is to create a "box" with the armour plates and stick the missile pod on one side. It would probably be easier to make the basic structure out of plasticard/cardboard and then put the armour plates as decoration. Edit: apologies but I don't have the dread at hand, so I cabnot get pictures. Link to comment https://bolterandchainsword.com/topic/354133-dreadnought-missile-launcher/#findComment-5266185 Share on other sites More sharing options...
sarabando Posted February 28, 2019 Share Posted February 28, 2019 missles from the warlord titan from Titanicus? Link to comment https://bolterandchainsword.com/topic/354133-dreadnought-missile-launcher/#findComment-5266301 Share on other sites More sharing options...
xenomortis Posted March 1, 2019 Author Share Posted March 1, 2019 Thanks all. I'll have a look at all of the above :tu: Link to comment https://bolterandchainsword.com/topic/354133-dreadnought-missile-launcher/#findComment-5266447 Share on other sites More sharing options...
