The Ambot - Very GCS feel
So i've just preordered the Ambot just because they look amazing. They have a very miner / GSC feel and I would love to use them in the army, either built as is and used for counts as or kitbash into something completely different.
They could probably be used to make an abominant in a Bladed Cog detachment, but i already have one and dont want double
Has any one got any suggestions on what could be done with these?
https://bolterandchainsword.com/topic/354325-the-ambot-very-gcs-feel/
Could do them as patriarch twins, the genestealers kissed humans at exact same time basically. Due to the gestalt nature of the hive mind there stronger together than a normal patriarch but the power is split between the 2. For bladed cog that’s why they were the “suits”.
Still unsure on this. Won’t really be able to tell what I could make until I have them
Is it too small to work as a Sentinel perhaps?
I was thinking I could do that and it would save me money for when I want to run my brigade (only have 1 sentinel at the moment)
The sentinels are on 60mm bases while the ambot are on 40mm. But I’m sure I have enough bit that I could bulk them out
So I’m pretty set on using the ambots as sentinels. Thinking of dropping them to all fours and shoulder mounting the guns.
Can any one suggest other bits that have got a GSC miner feel? Thinking’s legs from ork killa kans and the like
I opened them up last night. There actually quite a lot smaller than I was expecting,but still going to run them as sentiels
Please put some size comparison pictures if you get the chance.
I like the models, but would like to see some better pictures that show their actual size compared to say Ogryns, Sentinels an Abominant or some such.
So they are about half the height of a sentinel, bit bigger than an abominant. I’ve glued sub assemblies as I still don’t know what If I’m building them standing up or dropping them to all 4s. I’ll blue tac them and take some pictures for you though.
Something to note is you actually get 2 different pairs of legs so once you’ve built 2 you will have 2 pairs left over.
IMG 1131 (1)
Sorry it took a while. From left to right: Abominant, Bullgryn / Ogryn, Ambot 1 (on 60mm GW base), Ambot 2 (on 60mm non GW base, set on a riser), Sentinel.
As you can see there quite a lot bigger than an Abominant, slightly bulkier than an ogryn, but significantly smaller than a Sentinel. Even when i've stuck it on a riser to give it height it will still be smaller than the sentinel. I will be using GW's bases though so be maybe 5mm taller than Ambot 2 on the thinner base
Thanks for posting it. It gives a good view on the size difference.
I still really like the Ambot model, but I can see that its size makes it hard to proxy for anything in a GSC army.
Also I really thought the abominant was bigger too :-)
