So, I want to create a Daemonkin/Daemon Engine army with all the new goodies coming out.
What would the best build be do you think?
I'm hoping this will fit into 2000
HQ
Daemon Prince
Master of Possession
Troops
3x Cultist Squads
Elites
3x 10 man Possessed Squads
Heavy Support
2 Double Obliterator Squads
1x Maulerfiend
Flyer
2x Heldrakes
https://bolterandchainsword.com/topic/354348-daemonkin-army/
I would do something similar but we need to see in the end what everything will cost.
I was going to look at Prince + 2 masters of possession
A good dozen daemons,
3 or so Greater possessed.
duel oblits (or 3 in one, and 1-2 in the other)
Mauler for sure, possibly a tick dependent on its points value.
Then based off whats left try and fill out a battallion with cultists.
Build up from there. its a fairly beefy list with *LOTS* of wounds so I can see it definitely getting some work done.
I will definetly be making a deamonkin army as I loved the theme of possessed/daemon engines, but it's a little hard to really solidify a list just yet without knowing the pts cost of the new stuff, and whether or not there are more releases coming such as another new daemon engine (which I'd really love to see).
HQ
Daemon Prince
Troops
3x Cultist Squads
Elites
Heavy Support
1x Maulerfiend
Flyer
2x Heldrakes
 I think others have given you some good advice.. .points are going to make a big difference. I wish you could find a way to put some of that in Rhino's. ... but all being said I would strongly recommend a Renegade Legion tactic based army.
The beginning of 8th, this is essentially the type of army I used to play a lot of, although I had Spawns in there, just because. But the ability to assault after advancing can put huge pressure on some armies, and keeps foot based armies valid against faster opponents.
Do daemon princes from csm or daemon books count for the new daemon kin? I’m thinking a nurgle battalion with princes or heralds, plague bearers to tarpit and board control. Some bloat drones or PBC. Maybe that nurgle tree and then a detachment of nurgle marked alpha legion daemons raining daemon fore down range. Also after seeing that new havoc model I know I want a unit or two.
I hope they change greater posses to work more with daemons, but I think 1-2 of them running mid fiend or even back field buff machines and counter charging anything that comes to the back lines.
Basically I see a nurgle version of an iron legion siege type army which I believe fits the lore as mortarion him self designed things like the PBC crawler to up stage imperial machines.
Im now thinking:
CSM Battalion
HQ
Daemon Prince w/ Wings Khorne
Troops
Cultists(10)
Shadowspear CSM(10)
Shadowspear CSM(10)
Elites
1x Greater Possessed Khorne
1x Greater Possessed Slaanesh
Possessed Khorne(10)
Heavy Support
Slaanesh Obliterators(2)
Battalion Detachment- Daemons
HQ
Bloodmaster
Herald of Slaanesh
Troops
Bloodletters(10)
Bloodletters(10)
Daemonettes(10)
The Herald and Bloodmaster alongside the Greater Possessed make some killy possessed and Obliterators.
