Morticon Posted March 8, 2019 Share Posted March 8, 2019 Hey guys. Simple question here. What do the big tournaments (LVO, NOVA, Adepticon etc) require on lists for pregame choices?There are loads of strats that are chosen pregame. Powers and WL traits are supposed to be chosen pregame too, but there have been some tournaments that require you to do this for the entire duration of the tournament and have it noted on your list. How do you guys play it locally? And how do the big tournaments play it? Thanks in advance. Link to comment https://bolterandchainsword.com/topic/354391-pre-game-options-in-tournaments-wl-traits-powers-strats/ Share on other sites More sharing options...
Slasher956 Posted March 8, 2019 Share Posted March 8, 2019 I dont play tournaments...that being said Relics & any strats that allow relics or change of formations /keywords are done locally in the list build phase... Normally pick the WL & Powers at this point as well because of how people expect /want to use them. How ever if some one wants to change the WL, relics & Powers pre-game then yeah go for it... How ever in a tournament or tournament prep game I wouldnt allow you to after you've seen my army! (no tailoring to suit the forces against you...) Link to comment https://bolterandchainsword.com/topic/354391-pre-game-options-in-tournaments-wl-traits-powers-strats/#findComment-5272372 Share on other sites More sharing options...
Morticon Posted March 8, 2019 Author Share Posted March 8, 2019 How ever in a tournament or tournament prep game I wouldnt allow you to after you've seen my army! (no tailoring to suit the forces against you...) Though I totally get that, and would think its common to choose your stuff after getting your opponent, but potentially before list swap..... surely thats not up to you? I mean, surely that's up to how /when the TO has declared its done? (Which is essentially the question) Link to comment https://bolterandchainsword.com/topic/354391-pre-game-options-in-tournaments-wl-traits-powers-strats/#findComment-5272379 Share on other sites More sharing options...
Closet Skeleton Posted March 8, 2019 Share Posted March 8, 2019 The big tournaments have publicly available packs that explain this stuff. Link to comment https://bolterandchainsword.com/topic/354391-pre-game-options-in-tournaments-wl-traits-powers-strats/#findComment-5272429 Share on other sites More sharing options...
shanewatts Posted March 8, 2019 Share Posted March 8, 2019 Most of the larger tournaments are a little different in each of their methods. LVO only needed to have what character was your warlord set in list building, so trait/relic etc could be changed per game. Also LVO wanted any Vigilus formations used as part of list building as well. Link to comment https://bolterandchainsword.com/topic/354391-pre-game-options-in-tournaments-wl-traits-powers-strats/#findComment-5272590 Share on other sites More sharing options...
Morticon Posted March 9, 2019 Author Share Posted March 9, 2019 The big tournaments have publicly available packs that explain this stuff. Got any links? Link to comment https://bolterandchainsword.com/topic/354391-pre-game-options-in-tournaments-wl-traits-powers-strats/#findComment-5272935 Share on other sites More sharing options...
Exilyth Posted March 11, 2019 Share Posted March 11, 2019 ETC tourney packs: https://www.glasshammergaming.co.uk/latest-rulespack/ GW GT: uses 1750 pts and missions from CA2018. Also uses bigFAQ1 and bigFAQ2 and all errata from https://www.warhammer-community.com/faqs/ ITC tourney packs: https://www.frontlinegaming.org/community/frontline-gamings-independent-tournament-circuit/itc-2015-season-40k-tournament-format/ That's the biggest three metas. Do note that some events use modified versions of the above rulesets and sometimes even their own rules. Link to comment https://bolterandchainsword.com/topic/354391-pre-game-options-in-tournaments-wl-traits-powers-strats/#findComment-5274581 Share on other sites More sharing options...
Morticon Posted March 15, 2019 Author Share Posted March 15, 2019 ETC tourney packs: https://www.glasshammergaming.co.uk/latest-rulespack/ GW GT: uses 1750 pts and missions from CA2018. Also uses bigFAQ1 and bigFAQ2 and all errata from https://www.warhammer-community.com/faqs/ ITC tourney packs: https://www.frontlinegaming.org/community/frontline-gamings-independent-tournament-circuit/itc-2015-season-40k-tournament-format/ That's the biggest three metas. Do note that some events use modified versions of the above rulesets and sometimes even their own rules. This, from the ETC was helpful (thanks). MODIFIED PRE-GAME INTERACTIONS Follow this procedure to start your games at the ETC: 1. Roll off for who places first objective 2. The player winning the roll off now selects his warlord trait. His opponent then does the same 3. The player having won the roll off chooses his psychic powers. His opponent then does the same 4. The player having won the roll off chooses if he will spend CP’s for stratagems to purchase extra relics for any of his characters. His opponent then does the same. 5. Start placing objectives 6. Roll off for who chooses sides 7. Whoever did not choose side starts to deploy his first unit 8. Alternate deploying until done 9. Roll off for who starts, applying a +1 for whomever finished deploying first. In the case of re-rolling ties, the +1 still applies to any re-rolls that might occur. 10. Roll to seize the initiative 11. Pre-game deployment 12. Players announce their remaining available command points and clearly mark this somewhere for their opponent to keep track of d Link to comment https://bolterandchainsword.com/topic/354391-pre-game-options-in-tournaments-wl-traits-powers-strats/#findComment-5276725 Share on other sites More sharing options...
