How dumb would it be...
If you think about what a stormbolter does for you for 3 extra points, it's a no brainer on an efficiency level.
to get the equivalent amount of firepower a stormbolter provides over a bolter, you would have to spend at least 17 points (for another veteran).
Obviously you get another wound and fill a double battalion easier, but maximizing shots in a single unit also makes your stratagems more effective (+1 to wound doctrines, auspex scan, stem the green tide, eldat intercept, etc) and make your reroll auras easier to place.
  • 2 weeks later...
At this point the only reason I wouldn't take storm bolters would be that I'm taking primaris instead of regular veterans. Storm bolters are that good.
I chose to go the primaris route because converting my whole army to have storm bolters or building a bunch of old marines again sounds absolutely horrid! :teehee:
That being said storm bolters are probably the more competitive choice for now.
