Dr_Ruminahui Posted March 27, 2019 Share Posted March 27, 2019 So, I just bought the Slaaneshi side of Wrath and Rapture (so, Rapture) which has the new Fiend models in it. In the box, there is a new Fiend datasheet, which gives each model +1 W that the fiend datasheet in the Chaos Demons Codex and allows for a squad upgrade, which also isn't in the codex. Now, there has been no FAQ modifying the Chaos Demon codex (yet) incorporating the changed datasheet. So... can I field the Wrath and Rapture datasheet in my chaos demons army, or do I have to use the chaos demons entry? As well, if I can use the new datasheet, is the point cost the same? I can't see anywhere in the little booklets that come with the models that gives the point values. Link to comment https://bolterandchainsword.com/topic/354829-fiends-wrath-and-rapture-v-chaos-demons-codex/ Share on other sites More sharing options...
Panzer Posted March 27, 2019 Share Posted March 27, 2019 The Fiend Datasheet in the box replaces the one in the Codex. You can find everything in the CA18. Link to comment https://bolterandchainsword.com/topic/354829-fiends-wrath-and-rapture-v-chaos-demons-codex/#findComment-5285142 Share on other sites More sharing options...
Dr_Ruminahui Posted March 27, 2019 Author Share Posted March 27, 2019 Thanks, sfPanzer. Do you know where the points for the Infernal Enchantress are? Army Builder lists her as 80 points, but I didn't see her in CA 2018 so I'm not sure where the program got that number from. Link to comment https://bolterandchainsword.com/topic/354829-fiends-wrath-and-rapture-v-chaos-demons-codex/#findComment-5285396 Share on other sites More sharing options...
Panzer Posted March 27, 2019 Share Posted March 27, 2019 Thanks, sfPanzer. Do you know where the points for the Infernal Enchantress are? Army Builder lists her as 80 points, but I didn't see her in CA 2018 so I'm not sure where the program got that number from. The points are in the CA18. Page 126. Nevermind only the Fiends are there. Honestly I have no clue where the points for the Infernal Enrapturess are. :huh: Link to comment https://bolterandchainsword.com/topic/354829-fiends-wrath-and-rapture-v-chaos-demons-codex/#findComment-5285405 Share on other sites More sharing options...
Slasher956 Posted March 28, 2019 Share Posted March 28, 2019 Dont think the Infernal Enrapturess' points have been changed since W&R was released.... so she should still be using the points from the box. Link to comment https://bolterandchainsword.com/topic/354829-fiends-wrath-and-rapture-v-chaos-demons-codex/#findComment-5285920 Share on other sites More sharing options...
Dr_Ruminahui Posted March 28, 2019 Author Share Posted March 28, 2019 I couldn't see anywhere in the box where it gave the points - the various booklets give power level, not points. That said, I could be missing something - I only bought the Slaaneshi side, and while there are no points in the various little booklets that give the datasheets and assembly instructions, there could well be another book/booklet that has the point costs for the various units. It's not like I need the points cost, as it is in army builder, I would just like to know where it is so that I can confirm that army builder is correct. Link to comment https://bolterandchainsword.com/topic/354829-fiends-wrath-and-rapture-v-chaos-demons-codex/#findComment-5286305 Share on other sites More sharing options...
Panzer Posted March 28, 2019 Share Posted March 28, 2019 I've checked the points cost before ... when I still knew where to find them. In Battlescribe they are correct at least, you can trust those. ;) Link to comment https://bolterandchainsword.com/topic/354829-fiends-wrath-and-rapture-v-chaos-demons-codex/#findComment-5286457 Share on other sites More sharing options...
