Ideas for Iron Warriors bases
So I picked up to chaos halves of Shadowspear and will be painting them as iron warriors.
I have no idea how to base them though.
I’m looking for a quick and simpleish scheme, more than likely using the GW technical paints.
What would you evil lords suggest?
https://bolterandchainsword.com/topic/355010-ideas-for-iron-warriors-bases/
I would suggest Necromunda bases that come with all of the grating and scrap metal molded in. Then hit them with some Boltgun Metal, Skavenblight Dinge, and maybe some Typhus Corrosion here and there before picking out desired parts in brighter metals.
I'd so the opposite and suggest not having metallic bases on metallic models as the two will run together.
If I was doing the awesome mechanics bases (and they are) is go with a drab other colour instead, like how they painted the terrain.
That's the fastest by far. I go with:
Stirland battlemire
Agrax wash
Increasingly light drybrushes of:
Mournfang
XV88
Karak stone
Also pretty fast, you can see the results in my BA or Chaos plogs.
My idea is to run them as the fist exemplars that turned traitor and joint the iron warriors M32. I’m thinking of going for a reddy mud colour (I have 6 other armies all with different bases) and this is one I haven’t tried.
Maybe using Stirland Mud and a Ruiz’s rust drybrush
For my Iron Warriors I use a combination of the Sector Mechanicus and the Sector Imperialis bases from GW, for we play on an "urban warfare" table. :)
Mostly just primed with some sort of metallic and washed with a combination of Agrax/Nuln Oil and some Typhus corrosion.
In addition I am experimenting with weathering colors from AK Interactive, wich are really nice (take a bit of practice though).
As for texture paint I reccomend the Earth Texture Acrylic from Vallejo (200ml ~10,00€ vs. 24ml 6,30€). ;)
Stirland battlemire
Agrax wash
Mournfang
XV88
Karak stone
Can't agree more. Dont go for a metalic base on a metalic models. It will bore you to death to paint the same colors, and base are here to creat contrast.
So go with an urban base, but with snow on it, or a red martian type base, or mud.
https://www.games-workshop.com/resources/PDF/Blog/Textured_Paints.pdf
Here some help.
  • 9 months later...
I've been doing mine with a mixture of Stirland Mud and sector mechanicus/imperialis bases. I'm going to add some razor wire at some point; the theme is the army going "over the top" in a trench fight and breaching a wall (the scenic bases). I wanted to try to capture the army as if it were in the process of breaking a seige of an imperial city.
I use Stirland Battlemire, cover with a thick coat of Nuln Oil Gloss, then snow clumps in spots with Valhallan Blizzard.
I decided to go for the look of the conditions I (and most others) despise working in. It's cold, wet, and you're not likely to end the day without being chilled to the bone and wanting to rip someone a new one. I'd say add razor wire and that would match conditions the Iron Warriors have been dealing with since the Great Crusade.
  • 3 weeks later...
