Tournaments and modeling
Black Knight
I wanted to finish my Deathwatch Librarian in Terminator armour and he has a single option of either Combi-melta or just his bare hand in a casting posture.
If I build him with the simple casting posture has anyone been to a tournament that would not allow me to say he has a Combi-melta/plasma/etc in an army build?
Basically how heavily enforced is WYSIWYG at tournaments as I do not want to have to remodel him in the future.
1502570_300307943493314_9064465111685216
https://bolterandchainsword.com/topic/355102-tournaments-and-modeling/
Weapons that aren't just sidearms like pistols (when he has other shooting weapons) or grenades have to be on the model for GW tournaments afaik.
If you want to keep the casting pose you could just glue or magnetize the combi-weapon on his "belt" though I'd say (or rather hip plate).
I replaced the left arm with a grey knight arm and added a combi plasma where the storm bolter would go - falchion in hand. Then I have both weapons on one arm and can keep the casting hand free.
You could always add the combi to the base to make it look like he discarded it, have a servo skull hold it, etc.
GW tournes
I never really understood why there are Space Marine models with straps to their weapons when we get repeatedly told that they can just maglock everything to their armour with a simple thought.
Some folks think they are tacticool?
Aesthetics :) it’s the same with scopes on weapons when the marine helmets are meant to have targeting/vision systems built in. There should be no need for scopes. For the record I’m not a huge fan of straps but it will solve the modelling issue here.
I used to be super obsessed with WYSIWYG, but after realizing that hobbying is more important than chasing fleeting rules (my WYSIWYG models are now all illegal in 8E, thanks GW), I understand your concern. You should honestly care less about random tournaments and more about the model. If you like the casting hand pose, keep it. If you're going to participate in a tournament where this is a concern (and it will be a concern at most serious tournaments), just buy a loose pre-7E combi-melta bit from the old plastic commander or the FW upgrade kits, paint it up, and if anyone ever whines to you about the lack of combi-melta, pull out your tiny, painted combi-melta bit and toss it on the Librarian's base.
Thanks all for the replies, I really wanted to put a combi-plasma on him but the set didn't have one so I thought if I could get away with the hand pose it would be the best of all the options. Honestly the weapon on the base sounds like the best option for me as I tried magnetising smaller models before(Skitarii) and I really do not like the strength of those small magnets. It is the reason I use 5x2 on my Titanicus models as the 5x1 just doesn't feel strong enough.
Does anyone know of any kits that have the stormbolter style combi-plasma weapons, all I have is a ton of the normal bolter ones.
