Micro Art Studio Bases
coabeous
2 mm probably doesn’t make much difference but for me, I’m really flexible if my opponents want to use counts as models or proxy different things but I always insist the base has to be the right size because it actually affects the game (pile ins, how many are in combat, how easily they can get into cover, deep strike denial etc.)
You may also have a problem if you want to enter certain tournaments. Like I said, 2mm probably wouldn’t make much difference in that regard and I’d probably be ok with it but I think if the option is there like sfPanzer says, you should try and get the right size.
