DreamIsCollapsing Posted April 28, 2019 Share Posted April 28, 2019 Talking of kitbash, does someone got an idea for an Emperor's Children Helmet for the new chaos lord ? Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5303389 Share on other sites More sharing options...
El_Dicko Posted May 10, 2019 Share Posted May 10, 2019 Mixed the Heresy mark Termies with the new Chaos ones, mostly just arm swaps but I’m pretty happy with the results. Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5310617 Share on other sites More sharing options...
Freakshow668 Posted May 11, 2019 Share Posted May 11, 2019 I got the Havoc box and built a unit with 2 lascannons and 2 missile launchers. Then thought i'd make a chaincannon dude for a CSM squad (Lesson learned: stick the backpack on before the arms, makes it so much easier to link up all the cables/ammo belt). Used the remaining weapons and some CSM bodies to make a second Havoc squad with 2 autocannons and 2 heavy bolters. These guys are fairly straightforward This guy needed a bit of work on his backpack. Basically had to hack a normal CSM backpack into 4 bits to fit around the last Heavy bolter backpack piece. The exhaust vanes were cut off and stuck on to the sides, the socket at the bottom, that sticks onto the dude's back was cut off, the back shaved down and the sides trimmed so it fit into the recess on the bolter piece and the top bit, behind the head was trimmed to fill the hole at the top of the bolter piece. I reckon it'll look ok once painted and solves the problem of having one backpack too few in the Havoc kit. The champion just uses the CSM plasma gun with a chainsword stuck to his back. Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5311168 Share on other sites More sharing options...
El_Dicko Posted May 16, 2019 Share Posted May 16, 2019 So, I had leftover rocket launchers from my Havoc kits, and got to thinking about the new base size, and well had to get creative and kitbash some Havocs using loyalist Devastator parts and MKIII and IV, and veteran heads. Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5315659 Share on other sites More sharing options...
MegaVolt87 Posted May 22, 2019 Share Posted May 22, 2019 Talking of kitbash, does someone got an idea for an Emperor's Children Helmet for the new chaos lord ? Use one of the pretty boy bare headed BA ones. Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5318427 Share on other sites More sharing options...
Leonite Posted May 22, 2019 Share Posted May 22, 2019 I'm feeling fortunate, I haven't got it yet but I'm planning on getting the Master of Executions and adding a few small touches to make him look more Emperor's Children. Palatin Blade Helmet, possibly even with the topnot, might see how easy it is to deconstruct a sholder pad and stick the Emperor's Children logo onto the executioner, etc. Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5318543 Share on other sites More sharing options...
40kChrista Posted May 25, 2019 Share Posted May 25, 2019 I'm feeling fortunate, I haven't got it yet but I'm planning on getting the Master of Executions and adding a few small touches to make him look more Emperor's Children. Palatin Blade Helmet, possibly even with the topnot, might see how easy it is to deconstruct a sholder pad and stick the Emperor's Children logo onto the executioner, etc. It's not too hard to take off the rib-cage shoulder pad if you cut it carefully. Once you do that you could put on any arms you wanted, since the axe arm is completely separate. Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5320383 Share on other sites More sharing options...
Kraken Posted May 26, 2019 Share Posted May 26, 2019 Bitspludo has released some interesting Chaincannon bits: https://hexy.store/weapons-equipment/1726-chaos-rotary-cannon-x3.html Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5320443 Share on other sites More sharing options...
Leonite Posted May 26, 2019 Share Posted May 26, 2019 I'm feeling fortunate, I haven't got it yet but I'm planning on getting the Master of Executions and adding a few small touches to make him look more Emperor's Children. Palatin Blade Helmet, possibly even with the topnot, might see how easy it is to deconstruct a sholder pad and stick the Emperor's Children logo onto the executioner, etc. It's not too hard to take off the rib-cage shoulder pad if you cut it carefully. Once you do that you could put on any arms you wanted, since the axe arm is completely separate. I now have the model and I actually like the rib cage! Sorta seems like a trophy from when he had accidentally damaged the skull too much. Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5320467 Share on other sites More sharing options...
tdemayo Posted May 27, 2019 Share Posted May 27, 2019 Are the arms of the new multipart CSM models compatible with the plastic and resin legion heavy and special weapons? Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5321253 Share on other sites More sharing options...
Syrakul Posted May 27, 2019 Share Posted May 27, 2019 Looks like new kit has left hands built onto bolters (another knife in the back of multi-part kits) so while right hands hold the trigger grip left hand cannot hold supporting grip without some work or 3rd party bits. To clarify right hand you can chop at wrist and it works, but you are missing a left hand. Can either ruin bolter carving hand and grip off of it, or get hands from old kit/third party seller, like these https://conversionworld.de/index.php?pageId=suche&language=en&aktuellerTag=Hands&tag1=&tag2=&tag3=Body%20Parts&kategorie=Bitz%20by%20Compatibility Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5321257 Share on other sites More sharing options...
tdemayo Posted May 27, 2019 Share Posted May 27, 2019 I have some plastic mkIII and mkIV marines. I'll just use their arms. Link to comment https://bolterandchainsword.com/topic/355167-new-csm-range-kitbash-repository/page/4/#findComment-5321265 Share on other sites More sharing options...
