Daemonettes base size
Yeah, daemonettes are tiny compared to marines, and look fine on 25mm bases.
They would look really strange on a larger base.
One thing I would recommend is buying a box of 3/4 inch steel washers and glue them to the bases - costs only a few cents per model, makes them a lot more stable, and gives you more options for transportation.
Save your change and use the pennies. Ends up you'll save money that way lol
The box seems to come with 25mm? Is that what I should use for them, they seem tiny?
Ultimately it's up to you; if you think they look better on 32mm, use 32mm. There aren't any rules about base sizes in the game any more so while the above posts about 25 being the "right" size are not strictly incorrect, you aren't forced to adhere to that if you don't want to.
(I myself put all my Eldar models on 32mm bases despite 25mm being "correct", simply on the basis that I think it looks better.)
