Stercus Posted April 13, 2019 Share Posted April 13, 2019 Is it possible to use Primaris arms on tactical torsos and vice versa? I know that the shoulder pads and heads are interchangeable, but I can’t tell if the arms are longer on Primaris models without buying a whole box I don’t really want. Link to comment https://bolterandchainsword.com/topic/355286-primaris-proportions/ Share on other sites More sharing options...
Gederas Posted April 13, 2019 Share Posted April 13, 2019 No. Primaris have notably bigger Torsos and Legs. The arms of Primaris Marines are only slightly longer than non-Primaris, so using Primaris arms on non-Primaris looks weird, but the reverse is not true. See here with my "True-Scale" Deathwatch marines using Deathwatch arms: Link to comment https://bolterandchainsword.com/topic/355286-primaris-proportions/#findComment-5296033 Share on other sites More sharing options...
rendingon1+ Posted April 13, 2019 Share Posted April 13, 2019 No. Primaris have notably bigger Torsos and Legs. The arms of Primaris Marines are only slightly longer than non-Primaris, so using Primaris arms on non-Primaris looks weird, but the reverse is not true. See here with my "True-Scale" Deathwatch marines using Deathwatch arms: Link to comment https://bolterandchainsword.com/topic/355286-primaris-proportions/#findComment-5296066 Share on other sites More sharing options...
PeteySödes Posted April 13, 2019 Share Posted April 13, 2019 It’s possible yea, I’ve done primaris arms on classic marines and it’s fine. Link to comment https://bolterandchainsword.com/topic/355286-primaris-proportions/#findComment-5296148 Share on other sites More sharing options...
Stercus Posted April 14, 2019 Author Share Posted April 14, 2019 Cheers guys. I’m hoping to use Primaris arms and weapons to make non-Primaris Primaris guys for kill team. I like the rules but all my armies are set in a time frame well before ol’ Robby G rocked back up, so I’ll have to model them as veteran troopers with custom gear. Link to comment https://bolterandchainsword.com/topic/355286-primaris-proportions/#findComment-5296720 Share on other sites More sharing options...
Guest Posted April 14, 2019 Share Posted April 14, 2019 No. Primaris have notably bigger Torsos and Legs. The arms of Primaris Marines are only slightly longer than non-Primaris, so using Primaris arms on non-Primaris looks weird, but the reverse is not true. See here with my "True-Scale" Deathwatch marines using Deathwatch arms: How did you compensate for the narrower space for the SM arms to fit into the broader PSM. Link to comment https://bolterandchainsword.com/topic/355286-primaris-proportions/#findComment-5296724 Share on other sites More sharing options...
Gederas Posted April 14, 2019 Share Posted April 14, 2019 No. Primaris have notably bigger Torsos and Legs. The arms of Primaris Marines are only slightly longer than non-Primaris, so using Primaris arms on non-Primaris looks weird, but the reverse is not true. See here with my "True-Scale" Deathwatch marines using Deathwatch arms: How did you compensate for the narrower space for the SM arms to fit into the broader PSM. I didn't. The Deathwatch arms fit nice and snug against the Primaris Marine torsos. All I did was build the arms separately, then glued them onto the body after fully painting everything. In the second image, that Frag Cannon is staying on the Marine's body by pure friction. Link to comment https://bolterandchainsword.com/topic/355286-primaris-proportions/#findComment-5296730 Share on other sites More sharing options...
