Chaos Undivided
Rcketmouse
Two quick things to double check.
What does a Chaos Undivided detachment lose? Only the Daemonic Loci for the characters? Plaguebearers will still have DR and such right?
Also a Battlescribe question I can not get battlescribe to allow me to give the Skullreaver to a Khorne demon prince unless he is the warlord. If he is not the warlord the option for relics is there but doesn’t populate. Anyone else have this issue?
https://bolterandchainsword.com/topic/355292-chaos-undivided/
You must specify one unit to be the warlord. Then all characters can choose relics. E.g. Skulltaker is warlord, Khorne DP can take the Skullreaver.
I do have someone in another detachment as the warlord with a relic. Then I add the -1 cp for another relic to the detachment with the Khorne prince and the option for a relic shows but just show none as the only option.
Also thanks for the response about the Loci, I was pretty sure that was the case.
  • 2 weeks later...
