Samus Daemon Prince rule question
On his PDF rule sheet from the website:
Models in combat with Samus, as well as those taking Fear tests in order to charge him,
have their Leadership value halved unless Stubborn or Fearless.
Do you have to pass a fear test in order to charge him?
No.
This is taken from the new Book 8 and is worded just the same.
https://imgur.com/o1m7rO4
Shroud Bombs require a leadership test be passed in order to charge a unit as well.
So its not a typo.
It sure does look like you have to pass a leadership test at half value in order to charge Samus.
Well regardless of intent, a fear test only affects weapon skill. Not even going to mention the rest of his rules are horribly outdated in light of the new book.
Not really the rule is worded the same in book 8. Won't be a surprise FW copy paste machine failed at correcting some rule mistake
I was referencing the original post, where he talks about the pdf...which is very much outdated.
