Syrakul Posted April 19, 2019 Share Posted April 19, 2019 For my BL I want to make a squad of Rubric marines using a pile of DV chosen and wondering the best way to represent the bolter, ideally by converting regular CSM bolters. Maybe some sort of barrel mod, using fantasy chaos weapon hilts or something. I personally don't like the too-obvious Egyptian style of the real models, just want tzeentch-enlightened specialist looking dudes. I have a bunch of 30k volkite rifles I could also use somehow, though its not a rules match i doubt anyone would notice/care. Anyone use count-as rubrics before? Link to comment https://bolterandchainsword.com/topic/355414-non-rubric-rubric-conversion/ Share on other sites More sharing options...
the emperor is scottish Posted April 19, 2019 Share Posted April 19, 2019 For my BL I want to make a squad of Rubric marines using a pile of DV chosen and wondering the best way to represent the bolter, ideally by converting regular CSM bolters. Maybe some sort of barrel mod, using fantasy chaos weapon hilts or something. I personally don't like the too-obvious Egyptian style of the real models, just want tzeentch-enlightened specialist looking dudes. I have a bunch of 30k volkite rifles I could also use somehow, though its not a rules match i doubt anyone would notice/care. Anyone use count-as rubrics before? What about converting up the thunder strike cross bows or whatever they are called from the storm cast range? Link to comment https://bolterandchainsword.com/topic/355414-non-rubric-rubric-conversion/#findComment-5299375 Share on other sites More sharing options...
Aasfresser Posted April 19, 2019 Share Posted April 19, 2019 I'd suggest just swapping the heads on the regular Rubricae and maybe the backpacks with some of the new standard CSM ones. The Inferno Bolters have only the tzeentchian birdfaces on them, if this is to much for you there are even some without those bird ornaments. The runes are what make the inferno bolter obvious. If you want to use the DV chosen, you can just free hand some glowing runes and sigils on then weapon casing and you're good. Any TS player would recognize what this means. I converted some plasma-chosen back in 7th for my black legion with a heavy tzeenchian theme (Sons of the Cyclops). It's more the paintjob than anything else that makes them stand out amongst other BL troops, so that would be something to try. All but two are DV chosen, two of those are converted raptors. Link to comment https://bolterandchainsword.com/topic/355414-non-rubric-rubric-conversion/#findComment-5299385 Share on other sites More sharing options...
Syrakul Posted April 19, 2019 Author Share Posted April 19, 2019 Asafresser I've done something similar already as chosen in my gallery, but i swapped heads. This time ill likely keep the chosen style heads (though do have some of those forsaken heads about, like that one) and yes paintjob is important if I ever get around to painting them In this case I already have the core models so no intention of going and buying the rubrics. As for the crossbow idea... made me think of what other xenos stuff I might have to upprofile bolters, like DE bits like leftover shredder muzzles drilled out. Link to comment https://bolterandchainsword.com/topic/355414-non-rubric-rubric-conversion/#findComment-5299438 Share on other sites More sharing options...
Syrakul Posted April 20, 2019 Author Share Posted April 20, 2019 This is my soulreaper dude. Also as mentioned I’ve already got a squad of chosen I made for fun, so i would want some other aesthetic shift (like keeping chosen heads) for rubrics. Link to comment https://bolterandchainsword.com/topic/355414-non-rubric-rubric-conversion/#findComment-5299647 Share on other sites More sharing options...
McGibs Posted April 20, 2019 Share Posted April 20, 2019 I just swapped the heads on my rubric with wfb chaos knight heads. Gives them a cool black-knight look. There's not much else "egyptian" on the models once you take the helmet off. Link to comment https://bolterandchainsword.com/topic/355414-non-rubric-rubric-conversion/#findComment-5299828 Share on other sites More sharing options...
Jings Posted April 22, 2019 Share Posted April 22, 2019 I'm fond of sticking those small gargoyle heads from the chaos vehicle sprue to represent whatever weapon I need the unit to be holding, maybe that could be a plan? Link to comment https://bolterandchainsword.com/topic/355414-non-rubric-rubric-conversion/#findComment-5300330 Share on other sites More sharing options...
Syrakul Posted April 23, 2019 Author Share Posted April 23, 2019 I know the gargoyle heads you mean, rounded up a bunch too, but the smallest one is still quite wide and that conversion is rather cliche nowadays. I do regret not chopping this guys head, i might have a go at losing his side horns and adding some straight forward ones instead, loki style, from the daemon skulls in the skulls box. The gun is simple, based on the shoulder strapped rifle found on the pf chosen, carved down to the circle and voila! The fluff I invisioned involves strapping the skull of a possessed mortal psyker into the weapon, infusing the rounds with warp potency, sort of a controlled daemon weapon (daemon bound to mortal, mortal carefully sacrificed to trap the daemon, then skull/bones infused into the bolter) Link to comment https://bolterandchainsword.com/topic/355414-non-rubric-rubric-conversion/#findComment-5301229 Share on other sites More sharing options...
Syrakul Posted April 26, 2019 Author Share Posted April 26, 2019 I got more of the team built with the horn concept going on.. I like it in a earthy occult sense, though some of the posing is getting janky (my old CSM bitz box is wearing thin) I still have a bunch of symbols from the SoH etched brass that will go on their shoulders, so scraping left sides down. I’m also keeping wysiwyg so that means scraping off bolt-pistol holsters (leftmost is sorc, going to ‘empty’ his holster) The most common base chosen, the one wielding the bolter, is going to be a challenge to use as 5th man. His side-arm is heavily ingrained into his thigh/belt so maybe can turn it into a pouch? Link to comment https://bolterandchainsword.com/topic/355414-non-rubric-rubric-conversion/#findComment-5302457 Share on other sites More sharing options...
Syrakul Posted April 29, 2019 Author Share Posted April 29, 2019 Final squadmate wip, he will be holding aloft one of the gnarly daemon skulls with large horns from the skulls kit, almost like a ward (though kinda looks like ‘look what I found!’) Link to comment https://bolterandchainsword.com/topic/355414-non-rubric-rubric-conversion/#findComment-5303741 Share on other sites More sharing options...
Syrakul Posted May 2, 2019 Author Share Posted May 2, 2019 Final squad, so these are 5 rubrics with soul-reaper cannon. Link to comment https://bolterandchainsword.com/topic/355414-non-rubric-rubric-conversion/#findComment-5305646 Share on other sites More sharing options...
