No more 2++, but...
Soder
So if GWs intention was to not allow us access to any kind of 2++ they def missed the mark.. saw this on Dakkadakka, sharing.
“I like how in GW's quest to snuff out our 2++ combos (Heed, BroChamp) they neglected to edit the Warding Stave language... which was literally the SAME as Heed re: "add 1 to invulnerable saving throws".
Could this have been intentional on their part? Not likely. The more probable & sadder explanation is that they simply forgot about the Warding Stave and it's capability of RAW a 2++ in the Fight phase. Proving even more that GW doesn't give half a mind to think about GK more than they're required to.”
Originally posted by Nairul on Dakkadakka.
Do you guys think this was intentional or not?
RAW = Any unit with 4++ equipped with warding stave and sanctuary essentially still gives it a 2++ in the fight phase..
This would be possible to use on a generic GM and BroCap but probably not worth it anyways vs equipping a hammer. I def think it’s just a big oversight on their part!
https://bolterandchainsword.com/topic/355625-no-more-2-but/
It wasn't intentional, they forgot like they always do when they bend gk over the rails every :cussing faq. I swear to the emperor that this is a massive joke with how they keep picking away at everything GK have left. It'll be faqd soon to be nerfed so you never have a reason to use the stave anymore.
https://bolterandchainsword.com/topic/355625-no-more-2-but/#findComment-5304380
Why won't GW just write in core rules, that invulnerable saves always fail on rolls of 1's and 2's, if they want to do it in every army anyway? Really, quick and easy fix. Staves will be FAQed in September, I suppose.
Because Drukhari Archon shadow field exists.
https://bolterandchainsword.com/topic/355625-no-more-2-but/#findComment-5304867
Has Castellan Crowe avoided the 'Only In Death....' strategem nerf? Says (other than a Brotherhood Champion) in the rule when determining what characters.
So is that indicating that the Brotherhood Champion datasheet can't use it or rather the keyword itself, as I know CC has the keyword himself.
https://bolterandchainsword.com/topic/355625-no-more-2-but/#findComment-5305832
