Bolter Discipline Beta Rule Max Shots
Yeah, your buddy is cheating.
Bolter Discipline only gives new ways of triggering extra shots, it doesn't add a new doubling effect to get x4 shots like your buddy suggests.
You double your number of shots if ANY of the following apply, not EACH.
1.) Fire at a target within half range (normal rapid-fire)
2.) Be a TERMINATOR, BIKE or DREADNOUGHT
3.) Be stationary INFANTRY
The general rule for Rapid Fire is that you double the shots if you're in half range.
The Bolter Discipline rule is "Instead of following the normal rules for Rapid Fire weapons, models in this unit firing Rapid Fire bolt weapons make double the number of attacks if any of the following apply:
• The firing model’s target is within half the weapon’s maximum range.
• The firing model is Infantry and every model in its unit remained stationary in your previous Movement phase.
• The firing model is a Terminator, Biker, Centurion, Dreadnought or Helbrute."
Nothing says those effects stack. You don't double it for each of them, you double it if any of the conditions are true.
Otherwise, a stationary Terminator unit shooting at something within 12" would have 8 shots apiece. (Or 16, it the total doubled each time).
This idea was shut down pretty quick when the Beta rule was revealed originally.
I don't think it's much to do with people needing to learn to read, people know how to read, by and large. To me the issue is people reading in a biased manner (some accidentally, some deliberately). See to that effect the entry about the wobbly model situation in the latest FaQ in which GW expresses dismay at how people attempted to give meaning to the syndrome as some sort of rule... when it was always very clearly only there to protect models.
It say doubles the shots.
This is where you are going wrong as it doesn't just say that:
<Snip>
A boltgun has one attack. Instead of rapid fire (which is just a qualification for a weapon to use this rule), you use Bolter Discipline instead, and that is outlined as per the bullet points.
