sultansean Posted May 4, 2019 Share Posted May 4, 2019 I am currently assembling my first box of bikers, and I am considering magnetizing the lance arm for ease of transport. Has anyone done this before and have some tips and is it necessary? Thanks! Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/ Share on other sites More sharing options...
masterstrider Posted May 4, 2019 Share Posted May 4, 2019 The entire bike goes together VERY well. However, the lance arm is a complete pain in the A$$. This is because the shoulder pad does not sit very well; there are not enough contact points for the glue to sit nicely. What I did was to magnetise the arm with 3mm x 1mm magnets. Then I put a bit of green stuff between the shoulder pad and the arm, positioned it, let it set overnight and it came out very flush. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5306926 Share on other sites More sharing options...
shanewatts Posted May 5, 2019 Share Posted May 5, 2019 As far as transport is concerned, I think magnetizing the lance arm is a necessity. They aren’t hard to do and made transporting then so much easier. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5307653 Share on other sites More sharing options...
noigrim Posted May 5, 2019 Share Posted May 5, 2019 My two tidbits: glue the pears pointing forwards and put a putty donut in the base hole to insert the fkying stand, cut away the round point Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5307655 Share on other sites More sharing options...
Kruso Posted May 5, 2019 Share Posted May 5, 2019 I magnetized the arm and put a pin and magnet on the flying stand. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5307795 Share on other sites More sharing options...
sultansean Posted May 6, 2019 Author Share Posted May 6, 2019 I'm worried with magnetizing the lance arm that it is not going to stay "erect" any hints on how to make it more robust? Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5307980 Share on other sites More sharing options...
BLACK BLŒ FLY Posted May 6, 2019 Share Posted May 6, 2019 Pro Tip: I always mount the lances down to cut down on enemy line of sight . Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5307983 Share on other sites More sharing options...
faithonwings Posted May 6, 2019 Share Posted May 6, 2019 magnetizing the arms is the way to go. Transportation is almost impossible without. I use 3x1 mm for in the body but 3x3 for is the arms. The shoulder is thick enough for this and my advice for magnets is always 'the bigger the better'. Nothing more anoying than trying to move a model from one place on the table to the next and the spear falling of again. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5308056 Share on other sites More sharing options...
Danarc Posted May 6, 2019 Share Posted May 6, 2019 Can someone post some magnetised bikes pics pls? Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5308066 Share on other sites More sharing options...
Prot Posted May 9, 2019 Share Posted May 9, 2019 Honestly I found the magnetizing very easy. The shoulders have a good hole size for a lot of magnets, and the arm is similar: https://prot40k.blog/2018/07/07/custodes-project-redux-vertus-praetor-bikes-2-0-magnetized/ Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5310291 Share on other sites More sharing options...
Kruso Posted May 24, 2019 Share Posted May 24, 2019 I have a question that's close to this topic. How should I build the fly stand on Caladius? It doesn't seem to be very sturdy. Magnet on the bottom of the hole and on top of the transparent resin piece? Ideally I'd like to remove the tank from it's base for transporting. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5319863 Share on other sites More sharing options...
Prot Posted May 24, 2019 Share Posted May 24, 2019 Again... as in the link I provided the stand really should be magnetized if you can spare the time. It's a pain in the backside to do , but it is certainly worth it. The first set of bikes I did (in that link) sold for a lot of money compared to a set I did without magnets. That's how big a difference they make. Some people have come up with workarounds but the wear and tear can lead to problems. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5319884 Share on other sites More sharing options...
Kruso Posted May 24, 2019 Share Posted May 24, 2019 Again... as in the link I provided the stand really should be magnetized if you can spare the time. It's a pain in the backside to do , but it is certainly worth it. The first set of bikes I did (in that link) sold for a lot of money compared to a set I did without magnets. That's how big a difference they make. Some people have come up with workarounds but the wear and tear can lead to problems. I'm not talking about bikes, I got that covered. Caladius has a very different kind of stand, something I have not worked with. It's also fairly heavy model, so I'm unsure how to approach magnetizing it. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5319938 Share on other sites More sharing options...
Prot Posted May 24, 2019 Share Posted May 24, 2019 Oh sorry. Caladius is on a flat stand like a Repulsor for marines? I really don't know that stand, but if it doesn't use a stem, I imagine you could just 'pin' it? (That's what I did to a Repulsor). Unfortunately I don't know the base but I would suggest asking in the painting/Hobby forum for advice if no one has a good suggestion here. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5319941 Share on other sites More sharing options...
Kruso Posted May 25, 2019 Share Posted May 25, 2019 Oh sorry. Caladius is on a flat stand like a Repulsor for marines? I really don't know that stand, but if it doesn't use a stem, I imagine you could just 'pin' it? (That's what I did to a Repulsor). Unfortunately I don't know the base but I would suggest asking in the painting/Hobby forum for advice if no one has a good suggestion here. https://imgur.com/a/gPCbN These are the build instructions for Caladius. You can see the rod here. Pinning might be good idea. I'm going to research that option for sure. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5320253 Share on other sites More sharing options...
FelipeFlops Posted May 28, 2019 Share Posted May 28, 2019 I have a question that's close to this topic. How should I build the fly stand on Caladius? It doesn't seem to be very sturdy. Magnet on the bottom of the hole and on top of the transparent resin piece? Ideally I'd like to remove the tank from it's base for transporting. I went for the cheap and easy Blu-tak method. Keeps the tank from wobbling on the stand and the stand can still be removed for transport. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5321398 Share on other sites More sharing options...
Kruso Posted May 28, 2019 Share Posted May 28, 2019 I have a question that's close to this topic. How should I build the fly stand on Caladius? It doesn't seem to be very sturdy. Magnet on the bottom of the hole and on top of the transparent resin piece? Ideally I'd like to remove the tank from it's base for transporting. I went for the cheap and easy Blu-tak method. Keeps the tank from wobbling on the stand and the stand can still be removed for transport. I'm going to do the same, but I built a thin support rod on front too. Keeps it a bit more steady. It still wobbles a bit, which makes it feel like it's actually hovering. Like so: https://www.dropbox.com/s/do2bogdemraxhqm/IMG_20190528_153841.jpg?dl=0 Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5321516 Share on other sites More sharing options...
Ezr91aeL Posted May 28, 2019 Share Posted May 28, 2019 Pro Tip: I always mount the lances down to cut down on enemy line of sight . Super pro tip: Things such as wings, capes, weapons and stuff do not count for the line of sight. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5321673 Share on other sites More sharing options...
Prot Posted May 28, 2019 Share Posted May 28, 2019 Pro Tip: I always mount the lances down to cut down on enemy line of sight . Super pro tip: Things such as wings, capes, weapons and stuff do not count for the line of sight. Super-Duper-Pro-Tip! Magnetize the arms: This way you move the arm where you want, it fits in your cases easier, and if the tip breaks off it's easier to repair or replace! Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5321693 Share on other sites More sharing options...
Kruso Posted May 28, 2019 Share Posted May 28, 2019 Pro Tip: I always mount the lances down to cut down on enemy line of sight . Super pro tip: Things such as wings, capes, weapons and stuff do not count for the line of sight. This isn't true in 8th edition though. Unless you house rule it. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5321708 Share on other sites More sharing options...
Prot Posted May 29, 2019 Share Posted May 29, 2019 Pro Tip: I always mount the lances down to cut down on enemy line of sight . Super pro tip:Things such as wings, capes, weapons and stuff do not count for the line of sight. This isn't true in 8th edition though. Unless you house rule it. Actually i think you may be right. That’s an old quote from 7 th isn’t it? Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5321844 Share on other sites More sharing options...
BLACK BLŒ FLY Posted May 29, 2019 Share Posted May 29, 2019 If you can see even just a tip you can shoot. Terrible rule. Prot those bases are absolutely amazing. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5321895 Share on other sites More sharing options...
Lightbox Posted June 21, 2019 Share Posted June 21, 2019 Super-Duper-Pro-Tip! Magnetize the arms: I think you mean super-duper-PROT-tip! I'll see myself out... On another note those bases and lance tips are super awesome! I really need to get practicing with my airbrush. As someone who transports them with lance arms I would still suggest magnetising the arms, but if you keep the riders off like I do then you could get away with keeping them on and putting them in foam with the lances going flat over the top though this may not protect them enough in your case. Link to comment https://bolterandchainsword.com/topic/355717-building-custodes-bikes/#findComment-5334913 Share on other sites More sharing options...
