DaveyBoy74 Posted May 4, 2019 Share Posted May 4, 2019 Could you Please help me out, I'm stuck for Camouflage colours for my newly brought Shadowspear box set, I of course want to build & paint the Primaris Marines as Space Wolves, but I'm stuck on effect camouflage patterns / Colours - i.e. I don't want the overall colour scheme to be Blue/Grey heavy (for Urban Camouflage) if you know what I mean ?. Thank Guys. Link to comment https://bolterandchainsword.com/topic/355738-space-wolves-shadowspear-camouflage-pattern-ideas-help/ Share on other sites More sharing options...
Guest Posted May 4, 2019 Share Posted May 4, 2019 What is your armor plate color? Grey, blue, other? Is there a board you mostly play on, if so what are it's color pallettes. Or what are you bases designed as? All this is important, if you play mostly on a grey themed board, and the armor is grey you might want to do a different color to stand out a bit. If you have a snow base, then go white with thin lines if whatever the floral colors are (ie tan, green) Link to comment https://bolterandchainsword.com/topic/355738-space-wolves-shadowspear-camouflage-pattern-ideas-help/#findComment-5307394 Share on other sites More sharing options...
DaveyBoy74 Posted May 5, 2019 Author Share Posted May 5, 2019 What is your armornplaye color? Grey, blue, other? Is there a board you mostly play on, if so what are it's color pallettes. Or what are you bases designed as? All this is important, if you play mostly on a grey themed board, and the armor is grey you might want to do a different color to stand out a bit. If you have a snow base, then go white with thin lines if whatever the floral colors are (ie tan, green) Thanks, Sorry for taking a little while to reply, I'm using : Coat d'arms #150 Shadow Grey , as my main colour for the mini, the base will be greys with snow, I did a search on Google and found these : So I might try with my limited painting skills to d=use these as a guide what do you think ?. Dave. Link to comment https://bolterandchainsword.com/topic/355738-space-wolves-shadowspear-camouflage-pattern-ideas-help/#findComment-5307616 Share on other sites More sharing options...
Guest Posted May 5, 2019 Share Posted May 5, 2019 I would use a white tone as a base, and then a sponge with light grey to "stamp" a pattern on to it. Maybe some light browns to give it less of a monotone look This is a good tutorial, but in a larger scale. However you will get the basic concept. Link to comment https://bolterandchainsword.com/topic/355738-space-wolves-shadowspear-camouflage-pattern-ideas-help/#findComment-5307677 Share on other sites More sharing options...
DaveyBoy74 Posted May 6, 2019 Author Share Posted May 6, 2019 I would use a white tone as a base, and then a sponge with light grey to "stamp" a pattern on to it. Maybe some light browns to give it less of a monotone look This is a good tutorial, but in a larger scale. However you will get the basic concept. Thank you, I'll give it a try. Dave. Link to comment https://bolterandchainsword.com/topic/355738-space-wolves-shadowspear-camouflage-pattern-ideas-help/#findComment-5308033 Share on other sites More sharing options...
