Urauloth Posted May 8, 2019 Share Posted May 8, 2019 I really liked this colour, and I've run out of it. Does anyone know of a good replacement for it from another range, or a suitable mix for making your own match? I assume it can be reasonably duplicated by adding a brown of some sort to one of the darker steel colours out there, but I don't know which ones to start experimenting with and it'd be really helpful if there's someone out there who already has this knowlege. Link to comment https://bolterandchainsword.com/topic/355805-replacing-fw-iron-hands-steel/ Share on other sites More sharing options...
Imren Posted May 8, 2019 Share Posted May 8, 2019 I presume Vallejo model air steel doesn't have the same warm hue as FW iron hands steel. Check out the following ones: P3 radiant platinum, its a silver colour with a khaki-ish hue to it. Similar to (or perhaps same) as FW iron hands steel. Tamiya titanium silver, seems like a very close match on the pictures online. Check it out. Link to comment https://bolterandchainsword.com/topic/355805-replacing-fw-iron-hands-steel/#findComment-5309305 Share on other sites More sharing options...
Guest Posted May 8, 2019 Share Posted May 8, 2019 Did you try the Vallejo Metal Color (different than model and game color lines)line, they have a great color range of silver/steel colors. Edit: In case you need examples there is some on our forum http://www.bolterandchainsword.com/topic/346964-vallejo-metal-color-range/ Link to comment https://bolterandchainsword.com/topic/355805-replacing-fw-iron-hands-steel/#findComment-5309405 Share on other sites More sharing options...
Urauloth Posted May 8, 2019 Author Share Posted May 8, 2019 Good suggestions, thanks! The Tamiya titanium silver is a very good match. I'll check out the P3 colour as well, that looks like it might have a wide range of uses. Link to comment https://bolterandchainsword.com/topic/355805-replacing-fw-iron-hands-steel/#findComment-5309563 Share on other sites More sharing options...
