Brother Chaplain Tyranus Posted May 11, 2019 Share Posted May 11, 2019 Good morning everyone. I have been using a night scythe in my list as a troop delivery system to the back of the battlefield and I just want to see if you guys understand this the same way I do. So I've been putting 2 squads into the home tomb world to get teleported in to the night scythe. Now I'm using enhanced invasion beams to bring 2 squads out instead of one but the issue in question is what happens when the scythe gets destroyed. So I had first turn and flew my night scythe right to the other side of the field. My opponent shot it down in first turn so I used emergency invasion and enhanced invasion. Afterwards I had to consider though because enhanced invasion beams says whenever you use the invasion beam ability but by using emergency invasion beams does that supercede the invasion beams ability? I suppose it could be argued that by using the emergency invasion beams stratagem it could take the place of the invasion beam ability. Just wanted to see what your take on this was. Thanks Link to comment https://bolterandchainsword.com/topic/355882-invasion-beam-question/ Share on other sites More sharing options...
NTaW Posted May 11, 2019 Share Posted May 11, 2019 I absolutely want it to work, but you are using a stratagem and not the ability to disembark so the criteria for Enhanced Invasion Beams has not been met. Link to comment https://bolterandchainsword.com/topic/355882-invasion-beam-question/#findComment-5311617 Share on other sites More sharing options...
Mr4Minutes Posted May 12, 2019 Share Posted May 12, 2019 What NTaW said. The wording is the unit ability not the stratagem. It’s unfortunate. I do wish we had more access to things to bring units in from the tomb world. Like a DS stratagem or an additional transport unit. Its one of the Necrons unique abilities that isn’t properly taken advantage of. It’s a gamble putting 2 units aside with only one way to bring them in. Link to comment https://bolterandchainsword.com/topic/355882-invasion-beam-question/#findComment-5312134 Share on other sites More sharing options...
Brother Chaplain Tyranus Posted May 12, 2019 Author Share Posted May 12, 2019 Yea that's what I was afraid of. I tried a list with 2 scythes and it worked well. I'm finding it really hard to protect units like destroyers long enough to make them worth putting in my lists. Also getting lychguard into a good position in the back is nice. Link to comment https://bolterandchainsword.com/topic/355882-invasion-beam-question/#findComment-5312335 Share on other sites More sharing options...
NTaW Posted May 12, 2019 Share Posted May 12, 2019 For Destroyers, you could consider a Nephrekh Auxiliary Detachment and the Translocation Crypt stratagem, though now you're still spending 2CP now they're in reserve proper. For the Lychguard, I haven't really found anything better than using the Veil on an Overlord to whip them across the field. Link to comment https://bolterandchainsword.com/topic/355882-invasion-beam-question/#findComment-5312397 Share on other sites More sharing options...
