wulfgar hammerfist Posted May 12, 2019 Share Posted May 12, 2019 I had the chance to watch a couple of games of AM vs Chaos this weekend. It was pretty brutal for the AM player as Abbadon simply destroyed a big portion of the AM army by himself. He murdered bullgryn, guardsmen, and sentinels with relative ease. The AM had a good amount of plasma and other high ROF weapons but the character status made him largely un-targetable. How have you dealt with this murder machine? Link to comment Share on other sites More sharing options...
HallofStovokor Posted May 12, 2019 Share Posted May 12, 2019 He's pretty much the same as Guilliman, so you deal with him the same way. Kill the units he's buffing. Once they're gone, he's pretty much unprotected. Have an executioner, punisher or battle cannon unload into him. He halves the damage taken, so supercharged plasma is pointless against him. Link to comment Share on other sites More sharing options...
Steel Company Posted May 12, 2019 Share Posted May 12, 2019 Same way you deal with any super unit, volume of saves. If you can force enough of them he will fall sooner or later. Link to comment Share on other sites More sharing options...
ThatOneMarshal Posted May 13, 2019 Share Posted May 13, 2019 Kill the bodyguard unit depending on what it is, be it cutlists or terminators they all fall the same under a battle cannon. Once there you could either kill him or just try to rebuff him so that he’s useless like making him move half inch from the vigilus detachment. I think it would if you described how abandon was taken and what kind of units were with him. Link to comment Share on other sites More sharing options...
mertbl Posted May 13, 2019 Share Posted May 13, 2019 Spend 2CP for a vindicare. Problem solved, problem staying solved. Link to comment Share on other sites More sharing options...
domsto Posted May 13, 2019 Share Posted May 13, 2019 Abbadon is good in 2 things. Buffing stuff und killing stuff in Melee. First: kill the Units he buffs so his effect isn't that big during the shooting phase. It also opens him up to be shoot. He wants to be close to the enemy anyway. Secound: screening. He might be a monster in CC but has to come really close. So put layers of Guardsmen between him and your Tanks/importan Units. He might slaughter the 10men Squad but if there is no Unit in 3" to pile into, he stand alone and open to shoot him. Link to comment Share on other sites More sharing options...
MARK0SIAN Posted May 13, 2019 Share Posted May 13, 2019 You can also use your stratagems to chip away at him. Give your screens vox casters then fire on my position whenever Abby slaughters the squads. Don’t forget that Vengeance For Cadia affects overwatch too, which is exempt from character targeting restrictions, and can be combined with defensive gunners for vehicles and grenadiers for infantry. I’m not sure what regiment you play but if you’re Catachan you can also use viscous traps when he charges them. None of this is likely to kill him but is likely to at least chip away a few wounds and has only really cost you a few CP which guard are hardly lacking. Link to comment Share on other sites More sharing options...
WarriorFish Posted May 13, 2019 Share Posted May 13, 2019 I've killed old Abaddon plenty of times (with my CSM though!) - remove him of his protection so you can target him, then throw the sink at him! He's tough so takes some knocking down, but Guard have big enough guns :) Link to comment Share on other sites More sharing options...
MrZakalwe Posted May 14, 2019 Share Posted May 14, 2019 If he's deepstriking advance your infantry up the table turn 1 so he can't deepstrike anywhere near anything you care about. If he's not deepstriking do the same with your infantry as you want the enemy to get bogged down killing chaff sooner rather than later. If your infantry get tripointed so wont be able to retreat don't be shy of spending a command point to reroll a succesful morale check- sometimes you want your guys to run away. The Hammer of Sunderance with 'Pound Them To Dust and Vengence For Cadia will put more hurt on him than he expects once the bubble wrap is gone. Never forget Psychic Maelstrom as an option too- a dedicated Astropath for that isn't many points and that power can character snipe (no LoS required and no targeting restrictions). If you are playing Cadians the Relic of Lost Cadia is simply mental and makes the IG/Chaos matchup somewhat unfair IMO. Link to comment Share on other sites More sharing options...
wulfgar hammerfist Posted May 14, 2019 Author Share Posted May 14, 2019 Thanks for the replies. A lot of good advice. It is appreciated. When I can finally get a game in, I'll let you know how it went. Link to comment Share on other sites More sharing options...
