AppleCrumble Posted May 12, 2019 Share Posted May 12, 2019 Silly question but when assembling a Scion with Grenade Launcher, is there only one 'upper arm' piece (part 19, I think) that fits? If yes, are there any other right hand sholders that can fit without much work? Link to comment Share on other sites More sharing options...
Doof Posted May 17, 2019 Share Posted May 17, 2019 Cant remember the sprue exactly, but i believe the one arm issue is correct. The real question is should you be building your Scions with GLs? Most would agree that the scions excel at plasma and perhaps melta, with the regular Hotshot Lasguns as well as the Volleygun coming out on top of the GL. Link to comment Share on other sites More sharing options...
duz_ Posted May 17, 2019 Share Posted May 17, 2019 Annoyingly most Scion poses are fairly fixed You can try and mix and match parts, but it takes some trial and error to find the best alternative arm and some creativity I did it with some HSVG, I got there in the end its wasn't the most pleasant experience though EDIT:Doof raises a good point though, GL's arent the best option for them As much as I love GL's Scions benefit most from being run with Plasma's Melta was another good option for them, but until they do something about the 6" range of melta and reduce the cost again Plasma is your best bet Link to comment Share on other sites More sharing options...
