Token Posted May 14, 2019 Share Posted May 14, 2019 Is it correct that you need to role a 9 or better when charging after "deepstriking"? Is 8 enough? What about if you charge an enemy behind a barricade, barricades can be fought through 2" between? Please excuse grammar, spelling mistakes and such. Link to comment https://bolterandchainsword.com/topic/355961-deepstriking-and-charging-enemies-behind-barricades/ Share on other sites More sharing options...
Panzer Posted May 14, 2019 Share Posted May 14, 2019 You need to be more than 9" away so minimum 9.1". To get into melee you need to be within 1". 9.1" - 1" = 8.1 So yes you need to roll at least a 9 because you can't roll fractions. You can charge enemies behind a barricade just fine as charges don't require line of sight, however it would increase your charge distance if you can't get within 1" with the usual rolled 9. Barricades don't magically increase the range of your melee attacks. Link to comment https://bolterandchainsword.com/topic/355961-deepstriking-and-charging-enemies-behind-barricades/#findComment-5313880 Share on other sites More sharing options...
Jolemai Posted May 14, 2019 Share Posted May 14, 2019 ... unless they have a special rule such as the Aegis Defence Line. Link to comment https://bolterandchainsword.com/topic/355961-deepstriking-and-charging-enemies-behind-barricades/#findComment-5313888 Share on other sites More sharing options...
Panzer Posted May 14, 2019 Share Posted May 14, 2019 Yeah of course, special rules notwithstanding. Link to comment https://bolterandchainsword.com/topic/355961-deepstriking-and-charging-enemies-behind-barricades/#findComment-5313904 Share on other sites More sharing options...
