The Great Crusade Continues - ETL VII Prep
Looking forward to this and getting some painting done!
Just wanted to check if it’s ok to mix chapters within vows. For example, I plan to do a mixture of Templars and Celestial Lions. That should be fine right? Because they are both from the same forum (Codex: Space Marines).
Yes.
But there is a thin line between conversion and scratch-build. The former is welcome as the ETL promotes creative and modelling skills. The latter however is disallowed as, without wanting to pass judgement on anyone’s skill, often scratch builds are way more simplistic Thant the GW/FW originals. As such it would be unfair to those that put together and actually paint a fairly complex GW/FW original model in order to earn x points vs. someone who does a simplified version of it.
So if you have doubts by all means PM me to discuss.
I have my Termies ordered, still need to get some bits.
Hopefully I will finish my current project this week, so I can start assembly. Already kitbashed another Chaplain for counts as grimaldus and glued some chains to my next castellan.
I shall join in on this one around the 21st of June. The force will not be large, probably a couple of characters, but I'm in it for the sense of community so I'd say that participation itself is added value. And who know, maybe I'll be able to finish more stuff before the event's done.
Good luck to all Templars who have already started their work or are going to do so over the next two weeks!
